changing out the rear shocks
Old Sep 11, 2006 | 05:17 AM
marino1's Avatar
Unhappy changing out the rear shocks
howdy all!
long time lurker here... i've got an 01 sr5 2wd that i'm trying to change the rear shocks on, and having the darndest time getting to the top nut of the shock. anyone have any tips/tricks/writeups on how to change these bad boys out?
thanks in advance!
Old Sep 11, 2006 | 05:27 AM
User 051420's Avatar
Welcome to the forum.
Those top nuts are notoriously difficult to remove. I just stick a wrench up there, and jam it against the frame so the wrench can't turn on its own, then loosen it by turning the shock body. This is there a strap wrench comes in handy. Also, if you don't care about the old shock you can bend the upper part of it to get some biig channel-locks around it.
Good luck.
Old Sep 11, 2006 | 05:53 AM
ebelen1's Avatar
Or just saw off the shock (top thread) since you're replacing it. It was PITA to remove and me and my buddy had quite a few bruised knuckles from the process.
Old Sep 11, 2006 | 06:04 AM
ohio4runner4x4's Avatar
DITTO!
Old Sep 11, 2006 | 06:08 AM
marino1's Avatar
first off, thanks for all the replies!
...but how did you guys get the new ones on? it seems that the fuel tank/lines are right in the way to hold the bolt and tighten the nut at the same time...
i got the basic gabriel $32 shocks from autozone btw..
thanks again!
Old Sep 11, 2006 | 06:14 AM
BajaRunner's Avatar
Its so weird, I had no problems gettting those off the first time. As, so many people do. Try using some PB blaster and letting it soak up for a while.
Its easier just to turn the shock body and have the handle of the ratchet just sit up against something else.
Old Sep 11, 2006 | 06:57 AM
MTL_4runner's Avatar
Depends where you live.....if you're anywhere near the rust belt, then sawzall is definately the easiest way.
The new ones go on alot easier than the old ones come off to be sure.
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
icentropy
Jul 11, 2015 07:21 AM
icentropy
Jul 9, 2015 02:12 PM
HRDC0R19
Jul 5, 2015 06:43 PM
