caster maxed out on 97 4runner
Old 12-08-2004, 07:34 PM
Bigkahuna808's Avatar
Nah, most likley not, It was a fender bender. I'll try and get it checked. I did america a favor and hit a personal injury attourney
Old 12-08-2004, 08:27 PM
jimbo74's Avatar
a fender bender is still strong enough to tweak a frame....
Old 12-08-2004, 08:52 PM
really, I just might have a bent frame then. I'll go have it checked.
Old 12-08-2004, 11:03 PM
jimbo74's Avatar
as in frame, im also refering to frame mebers... the frame could be bent, but dont rule out other little things like bent control arms, that can just as easily have done it....
Old 12-09-2004, 01:56 AM
  #25
Man this sounds like a costly check to perform. Anyone know what a frame inspcetion woud run?
Old 12-09-2004, 08:42 AM
  #26
Cliff s's Avatar
Many years ago I worked in a Front End shop and it was quite
common to find out of spec. camber and caster. We had a
60 ton air jack and some large chain the we chained the
front end too and then bent it back into spec.
Most body shops never check the frame or body aligment
after an accident.
If you have modified the front end, the adjustments might
not make spec. If that is the case, then you have to modify
the control arms or their mounting to make the spec.
Cliff s
Old 12-09-2004, 09:52 AM
  #27
Thanks for all the info guys, Im stuck in a retail job. So as of today I wont see the light of day untill the new year. So thats when Im gonna get it checked.
Flying91
45
04-11-2024 04:39 PM
icentropy
09-16-2020 02:47 PM
BeMiceElf
10-10-2015 09:40 PM
Jdgarrison
10-01-2015 05:22 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: caster maxed out on 97 4runner
