YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 01-08-2013, 01:01 PM   #1 (permalink)
Personal Sales Rating: (0)
Can a overheating tranny cause coolant loss?
So I was out 4x4 ing in my 2000 3.4 sr5 on a snowy logging road and I guess I was giving my tranny a workout cause the temp light came on. I stopped, turned around and coasted downhill till the light went off, about 5 mins later. Since then I have changed the tranny oil.
Just today my engine temp gauge was higher than usual (this has never happened before), check the coolant level and the reservoir was dry. Topped up reservoir and radiator. Guess time will tell now.
My question is: when I overheated my tranny would that have caused a coolant loss in any way??
Thanks!
livinlarge is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 01-08-2013, 01:06 PM   #2 (permalink)
HighLux's Avatar
tranny temp light was on? hmm. thats no good.
You changed trans fluid...I assume no coolant in trans fluid.
Radiator was low. Hmm.
Trans fluid smell burned? Really dark?
Were did the coolant go.
__________________
1981 Trekker!
1987 4runner 22r 5spd 31x10.5's
Engnbldr rv head 268 cam Lc header
1999 4Runner Limited w/locker.
2001 Tacoma Prerunner 3rz Auto. 31's.
HighLux is offline
Old 01-08-2013, 01:23 PM   #3 (permalink)
Threadstarter [OP]
Yes the tranny fluid was definitely burnt and darker. However I wouldn't say really dark. Not that I'd know what to look for but it don't think there was any coolant in the tranny oil.
Something just occurred to me! A couple days after the 4x4ing a buddy said he smelled coolant when I picked him up. I guess it was leaking then, should have check reservoir levels then.
Old 01-08-2013, 04:06 PM   #4 (permalink)
mudpunisher's Avatar
Send a message via AIM to mudpunisher
usually its the other way around, a loss of coolant will cause the tranny to overheat. give it a good look over, may have to get a pressure tester
__________________
1985 4runner
OME lift
mudpunisher is offline
Old 01-16-2013, 08:18 PM   #5 (permalink)
Skidmarcx's Avatar
Agreed... sounds like the loss of coolant caused the trans to run hot
Skidmarcx is offline
Yotatech
4WD Truck
Paid Advertisement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
