Can I port & polish my own heads? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-28-2003, 09:35 AM   #1 (permalink)
mycotopian's Avatar
I found a cheap pair on ebay to try it on. that that way I minimize my downtime. I want to do a P&P and a performance rebuild on them. What else needs to be done while I have them apart. What are the best type of valves etc to put in there.
I have read several articles online that say its a piece of cake and only requires a dremel and some grindine stones is this true?
__________________
1999 4runner 3.4 4X2 150,000 miles
ISR Mod
Tundra/OME Lift
Addco sways on the way! (damm backorders)
mycotopian is offline
Old 08-28-2003, 10:25 AM   #2 (permalink)
rimpainter.com's Avatar
I wouldnt mess with them. I would drop them off at a known pro and have them done. Its not worth the R&R only to find out you didnt do it right.
I just bored out my TB, and its not as easy as it looks with a dremel. I can only imagine how long it would take on a pair of heads.
rimpainter.com is offline
Old 08-28-2003, 10:33 AM   #3 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
It is definately not a piece of cake and takes a long time to do on iron heads (aluminum is much softer). You will go through a TON of grinding stones. The best way is to get a carbide bit (they are expensive) and an air grinder.....still takes a long time to do even with that setup. I would do what 96runner says and take it to a pro unless you just want to have fun and experiment.
I would suggest if you do go it yourself to just do the exhaust and leave the intake side alone. The rough surface (unless your turner your runner into a dragster) will help quite a bit on the torque department.
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Old 08-28-2003, 10:36 AM   #4 (permalink)
I am pretty sure we have aluminum heads and an iron block. Sorry if I misunderstood your response MTL...
just wanted to clear that up.
Old 08-28-2003, 10:45 AM   #5 (permalink)
Send a message via AIM to Zubaltec
First off don't even try to learn how to port on a head or set of heads that your going to plan on using. You'll find it a big waste of time. You won't get the ports to match without a flow bench. People who port head use electric drills not air tools. This way you can regulate the speed by a switch and not by feel or with your ear.
Just my .02.
Thanks,
John
__________________
07 Tundra RCSB 5.7
SOLD-'99 SR5 Highlander- TRD SC, URD 2.1 pulley, Flex-a-lite fans, Edlbrock headers (ported, HPC, wrapped), test pipe, URD O2 simuiator, Borla exhaust, TRD thermo., NGK plug wires, URD/Splitsec FTC, Bilsteins, Addco w/ES bush., Volk TE37's on BFG gforce KDW's, URD Speed Unlimiter, IPT Valvebody,B&M trans. cooler, Trutrac w/4.88, JAOS Rear Wing, Hilux Surf clear corners, 96 bumper w/PP lower valance, Bushwacker fender flares
14.9 @ 89 and 19 mpg
Titanmotorsports.com
Zubaltec is offline
Old 08-28-2003, 10:45 AM   #6 (permalink)
Your totally right 96runner (we do have aluminum heads....din't mean to confuse anyone) so it will be a bit easier than iron, but as I am sure you can attest to aluminum can be tough to work with too because it doesn't self clear very well (in other words it likes to stick to the abrasive) when you sand it.
mycotopian, Just take it slow and you should be ok.
__________________
- Jamie
Old 08-28-2003, 11:06 AM   #7 (permalink)
Cool, we were on the same page.
Tags
4runner, 57, aluminum, cana, dremel, drill, head, heads, polish, polishing, port, porting, ports, tools, tundra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
BitTorrent & Port forwarding, do I want to do it, if so how? 4-RUNNIN' FREAK Computer Talk 14 10-20-2005 01:16 PM
port & polishing in california, ok? needayota 95.5-2004 Tacomas & 96-2002 4Runners 1 02-21-2004 03:53 PM
Do your own port & polish? Los Gatos? 95.5-2004 Tacomas & 96-2002 4Runners 10 05-23-2003 10:46 AM
Will port & polish affect mileage? HaveBlue 95.5-2004 Tacomas & 96-2002 4Runners 3 03-07-2003 12:08 PM
2009 InternetBrands, Inc.
