Cam shaft sensor connector
Old 08-21-2015, 10:00 AM
Tacoma1313's Avatar
I was looking at different connections in my engine bay (3.4L) and noticed that the wires for the camshaft sensor leading up to the connector clipped to the timing belt cover has frayed wires exposed out of the heat shrink surrounding the two that go to the connector. The frayed strands dont look like they're from the two intact wires, just surrounding them. If this is causing a short, what symptoms could occur in my engine?
Old 08-21-2015, 10:10 AM
wyoming9's Avatar
Red face
A short can cause a few things to happen
If there is protection in the circuit it will open Without any major carnage being caused.
Non protected circuit current flows to the power source is depleted or the circuit opens .
This can cause lots of heat which may result in a visit from the local fire department
Blamalam
03-12-2022 07:34 AM
mussy01
12-13-2016 08:20 PM
raptor510
08-19-2015 02:15 PM
88yodabasket
07-13-2015 01:32 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Cam shaft sensor connector
