Brighter headlights
Brighter headlights
I have a 97 runner and I noticed that when it rains, my head lights aren't worth squat. Aside from PIAAs or other fog/driving lights (that i will eventually get) is there anything I can do to brighten up the road? Unfortunately I have frosted head lights as well as frosted clear corners at the moment...
thanks
thanks
I don't know about the frosted aspect of your setup, or how that would effect other lights ... but I use sylvania silverstar bulbs and they are a lot whiter, and brighter, than my stock bulbs. You could always just try something like that ... they aren't too, too expensive, but they can make obvious improvements.
https://www.yotatech.com/forums/f2/installed-sylvania-silverstars-worth-4971/ ... there's a thread that might help you out some.
Originally Posted by 4route
https://www.yotatech.com/forums/showthread.php?t=4971 ... there's a thread that might help you out some.
Yea.. my bad, I've been here long enuff to know that I shoulda 'searched' first. My bad...
thanks
thanks
Personally I splurged part of my tax refund into late model glass and silverstars. Its better. maybe 15% improvement. Additional lights are still needed for those late night, middle of nowhere, storm conditions.
All I have to say is switch to Hella Yellowstars. Barnone the best replacement bulbs for our trucks yet. I have used Piaa's and I didn't like the fact that I can see the road in foul weather. They emit a yellow tint to the light which is perfect in foul weather.
www.rallylights.com
www.rallylights.com
I have Silverstars on my stock '97 setup and they are brighter than the '99+ clear version with regular bulbs but I'm sure that would change with putting Silverstars in the clear headlamps.
I compared mine to my mom's stock '99 setup.
www.rallylights.com
www.rallylights.com
130/90W are cheaper than the 80/70W and 110/85W
Location: Home: Aurora, CO; Work: The People's Republic of Denver
www.rallylights.com
www.rallylights.com
I have Cool Blues, and I DO NOT like them at all! They disappear as soon as it gets cloudy. I have also noticed that the yellow light does a much better job.
It's sort of like using an LED flashlight to see long distance. You can see up close really well, but the light just doesn't travel.
I love my vision plus bulbs. Best normal headlight bulbs I've ever used. Great range and brighter than stock bulbs. They're pretty decent in the rain I guess but like someone mentioned before, the only real way to get good lighting in rain is to get a set of yellow fog lights. That or spend a few hundreds for real hid's which will light your way through almost anything.
You guys have to upgrade to a True H.I.D. Kit then you will know what headlight beams are. I've had mine in just over a year now and will never go back to regular bulbs. Foul weather never stands a chance against my H.I.D.'s. And the way they warm up is the coolest.
