Brakes upgrade w/ 15" rims on 98 Tacoma
Old 08-13-2010, 04:50 PM
abd9810's Avatar
If I knew about the tundra swap last year I would have upsized the tire/wheel combo to 16" Too late now. What can I do to improve my brakes on my '98 4x4 tacoma with 15" stock cast alum wheels? It's time for a brake job.
Old 08-13-2010, 11:30 PM
awdjunkies's Avatar
Most often people associate better brakes with bigger brakes. Not always the case. Sometimes its as easy as upgrading your pads on OEM rotors. You can also upgrade your rotors with a better heat dissipation type rotors, such as slotted(Not to be confused with cross drilled).
Old 08-13-2010, 11:37 PM
awdjunkies's Avatar
Stoptech, Axxis, and Hawk, are just some of the companies that offer aftermarket/better brakes for just about any vehicle on the road today. Also replacing/going with a stainless steel brake line with a higher temp. Brake fluid makes all the difference in the world.
Edit**
Here is a quick glance at what you have to work with(At least with this company): http://store.zeckhausen.com/catalog/..._489_2549_2551
Good Luck!!!
06-01-2021 01:51 PM
1uzRunner
63
11-10-2018 03:58 PM
stanz
10-30-2015 10:33 AM
Patrick1976
09-15-2015 11:33 PM
Flying91
09-10-2015 03:41 PM
Quick Reply: Brakes upgrade w/ 15" rims on 98 Tacoma
