body lift removal....HELP!!!
Hey guys i've got a 92 yota pickup with 4" suspension 3" PA body lift... well i was going to run 35s but with these Gas prices going up i can afford to feed my lil truck. So i've decided to remove the body lift... only thing is i don't have any instructions/stock parts, i think i need the stock firewall(steering) but i'm not sure.. if ANYONE has the instruction for the install/removal... or can just help me out anyway possible i'd appreciate it... this is also my 1st week of being on here THIS PLACE ROCKS MY FACE OFF!!!! PLease help me.... :cry:
well i dont have a fancy 92 yota, but i did have an 86 with a 3" body lift that i removed, its a very simple process. youre gonna need all new body mount bolts and new rubber or poly spacers between the frame and body, i guess you could use the old spacers if you had them, anyway just get a buddy to help you and it should be a breeze. when i did mine i did it one side at a time, just pull out all the body lift spacers, then go to the other side and do the same, make sure to keep an eye on your steering linkage tho, if theres a pin in it drill or pound it out(i can post pics if you need me to) and make sure not to bind any brake lines or clutch lines. any way if you need more just ask.
You will just have to reverse the process.
thanks fellas i do believe i'll give it a shot this weekend. I've got a little cuz that interested in learning this stuff... so body lift 101 starts in 3 days....wish me luck
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
Backcountry411
07-24-2015 08:06 AM
