A BIG weekend!
Wow, it's like a whole new truck. Quick question, could you tell me what the extended and compressed length of the stock front shock is if you still have one?
Thanks
Thanks
#26
If you'd like, you can buy 'em and check yourself!
https://www.yotatech.com/forums/show...threadid=20769
Originally posted by smr4runner
When are the tires coming?
#28
Originally posted by loosehead
Well done, guys!
Mark, your Runner looks great! What kind of tuning did you have to do to be able to run the 160* T-stat?
Well done, guys!
I didn't specifically tune for the t-stat, the tuning that I refer to was basically Dr. Z doing what he's been trying to get _me_ to do for the last few months with the SMT-5. It's a LOT easier to work that box with two people - one driving and one with a laptop in their lap.
You find an empty stretch of farm road, tweak, then punch it for 1/4 mile. You listen for pinging, look at your 1/4 mile times, then repeat. We spent over an hour running back and forth.
The only specific tuning for the t-stat per se' was to reset the electric fans to come on at 189*. They do, and the truck is running at a coolant temp of 172*.
#29
O.k. I am beginning to understand...I would be really curious to see what king of HP/tq #'s you guys have now...
The truck really does look good, funny what a little lift can do, eh?
I must admit, though, I have bumper-envy!
#30
We worked with one of these boxes http://www.auterraweb.com/, but didn't get what we thought were "reasonable" HP numbers out of it. That box uses the classic "if you push this much weight this far in this amount of time, you have this much horsepower" math to come up with a number.
We're thinking that we may have had a couple of user supplied variables wrong, 'cause the numbers being shown were around the 137-142hp mark. The 3.4L puts out 183hp stock, or 137bhp (figuring a 25% loss for an automatic), and I know I'm making more HP than that.
#31
To add to Mark's comments regarding tuning:
Besides listening for pinging, we look at Long Term Fuel Trim and try to get it as close to Zero as possible for the Closed Loop portion of the maps. For WOT, we try to shoot for an O2 Sensor voltage between .83-.85 Volts, which equates to 13.3-1 to 12.5-1. We do this by adding or subtracting fuel in the WOT column of the Fuel Map.
For the Closed Loop fuel tuning, we used the Fuel Zero setting of the SMT-5 to get LTFT to "0". I find that it works better and seems to give smoother Throttle Response than by populating the maps with individual numbers. A +/-1 in Fuel Zero equates to about +/-5% LTFT. Mark's truck required a +4 Setting in Fuel Zero to get LTFT to near "0". His LTFT runs between 0.8 and -0.8. Before the changes, LTFT was around 15-18%.
If there are cells in the maps where LTFT is outside of this range, we populate those particular cells with a positive or negative number to reach "0". For instance, the Idle cell needed some correction in the negative to reach LTFT of "0". All of this really does improve driveability by quite a bit. It makes the engine a lot punchier.
After all of this is done, then we try to set maximum Timing Advance for the grade of fuel that he's going to run. We also set up both the A and B maps since Mark hooked up the Map Switch.
Mark had a tankful of Mid Grade gas and I could run about 8* more advance over the stock settings at all throttle positions with no pinging whatsoever. We loaded the engine pretty hard to make sure it could deal with those settings. That is the "A" map.
For the "B" map, it's set to about 3* more advance over stock, which he can use for Regular Unleaded and possibly the trail with Mid Grade if the "A" map causes pinging when in 4WD and under a heavy load. The truck was pretty heavily loaded with all kinds of gear and his left over original parts from the install, so I'm pretty confident he'll be good with those settings. The fuel settings are identical between the two maps, since that doesn't change with Octane.
We also tweaked the Analog Scale Deflection since his throttle position sensor percentages were slightly different than on my truck. At idle, using the settings I had given him, the cursor was bouncing between back and forth between the first two columns. After adjustment, it stayed in the first cell, which is where it's supposed to be.
Maybe Mark can take some screenshots of his maps and global settings and post them.
G
G
#32
I've seen a couple of "new" folks on this thread, so I wanted to point out that when we're talking about "tuning" or mention the "SMT-5", we're talking about this:
https://www.yotatech.com/forums/show...&threadid=5130
(I'm SUCH a tease!)
#34
Originally posted by midiwall
I'd love to (and will!) but at the moment the truck is "at the place" doing "the new mod" that "I'm incredibly excited about"!
(I'm SUCH a tease!)
(I'm SUCH a tease!)
...living vicariously through other's mods...
#36
Jayson,
He'll probably share at around 6:30 pm...
Jayson,
...assuming nothing goes catastrophically wrong.
#37
He'll probably share at around 6:30 pm, assuming nothing goes catastrophically wrong.
Info update postponed 24 hours. argh.
#38
I'll let you in on Mark's secret, lets just say it involves a pink umbrella and a rainbow sticker on the back window- he's taking the term "street queen" to a whole new level....
#39
Dang you David! I wanted it to be a surprise!
(hey, I just noticed that my sig mod list is getting as long as yours. Hmmm.. what else can I do??)
