bad coolant leak
Old 06-14-2004, 08:40 AM
needayota's Avatar
bad coolant leak
hey all, i finally got my truck started after the hg change. drove it and when i got home i went inside. then i went back outside and a HUGE puddle of coolant under the car. i know its leaking from somewhere around the air chamber/intake manifold area. so my question is WHAT and Where could coolant be leaking from on that side of the engine???????
Old 06-14-2004, 08:43 AM
keisur's Avatar
maybe you hooked the water hoses to the bottom of the throttle body wrong or not good enough? uh, if yours has one that is.
Old 06-14-2004, 02:27 PM
needayota's Avatar
there is a large hose that connects to the bottom of the TB. hmmmmmmm maybe thats what it is.
i actually saw some leaking from the pipe that plugs under the intake mani. but im not sure if that has any coolant flowing through it.
jasonty
41
12-23-2018 01:00 PM
scottyg486
07-19-2015 05:34 PM
jakebarrett
07-10-2015 07:15 PM
Poncho0206
07-10-2015 06:21 PM
Avenged
07-09-2015 07:55 AM
Quick Reply: bad coolant leak
