Anyone have a Factory Service Manual for an '01 4Runner?
If you do, I've got a question. I need to know the front end alignment specs that the factory recommends. I believe that my vibration problem with my new Revos is due to a slight mis-alignment, and I want to have these numbers with me when I go to have it re-aligned. Thanks guys.
Matt
Matt
Are the tires properly balanced?
I copied these 4WD specs straight from my 2001 FSM:
* = Degrees
Camber (Left-Right Error)
-0* 15’ +/- 45’ (-0.25* +/- 0.75*)
30’ (0.5*) or less
Castor
3*05’ +/- 45’ (3.06* +/- 0.75*)
30’ (0.5*) or less
Steering Axis Inclination
11*00’ +/- 45’ (11.00* +/- 0.75*)
30’ (0.5*) or less
Toe-In
A+B: 0*12’ +/- 12’ (0.2* +/- 0.2*)
C-D: 2 +/- 2mm (0.08 +/- 0.08 in.)
* = Degrees
30’ (0.5*) or less
Castor
30’ (0.5*) or less
30’ (0.5*) or less
Toe-In
Road Bull
10-10-2015 04:55 PM
