------------Alternator Question------------
Old Dec 7, 2004 | 01:32 PM
getitdone's Avatar
my alternator is pooping out on me and i need to replace it. i am thinking of running a high output alternator. i dont have any need for it right now but i want to eventually add some aux lighting, powerful inverter, carputer stereo thing, and maybe even a winch. I also want to have a duel battery setup, but as of right now, i only have a red top optima.
Question #1: can i run a duel battery alternator with just one battery untill i save the cash for another optima?
Question #2: what brands should i look for?
i want to replace all components in my truck with premium parts. can you point me in the right direction?!
Old Dec 7, 2004 | 03:09 PM
AzStorm's Avatar
check this out
http://www.eurekaboy.com/f250/mechman.htm
then go here and contact Dennis.
www.mechman.com
Im running a 200 amp alt from him and it absolutely ROCKS!!
Old Dec 8, 2004 | 10:03 AM
getitdone's Avatar
look
i just found this http://search.ebay.com/high-output-a...ectZ1QQfromZR8 in ebay.
it looks like a good deal to me. 200 amps for 200 dollar on average and there isnt a lack of supply.
i know you can adapt a ford or gm to a toy but does it matter what year?
would i only need to fabricate a bracket or do i need to mess with rewiring?
if so any tutorials or testimonials?
Old Dec 8, 2004 | 12:45 PM
AzStorm's Avatar
Yes youll need to re wire and the bracket would be tricky as the steering knuckle is VERY close to the alternator.Aftermarket alts are bigger cases and can be a REAL nightmare to mount without touching.
This is one of the reasons I went with Mechman.All the cables were supplied with ends allready on them and each end labled for location.The bracket was also a perfect fit.
Remember YOU GET WHAT YOU PAY FOR!!
I just gave a testimonial as well as giving the link to a testamonial and an install.Werent you paying attention??
Old Dec 9, 2004 | 08:58 AM
Albin's Avatar
Here's what I did for my '85 Toy 4Runner:
http://www.rocketcityrockcrawlers.co...lt_Upgrade.htm
I hope this helps.
Thanks,
Al
Old Dec 9, 2004 | 01:56 PM
midiwall's Avatar
I'm running a high-output from Mr. Alternator.
It was a direct swap on the factory brackets. The only downside thus far is that you need to be running at a bit of a high idle (about 900rpm) for it to kick in it's 2nd set of windings (the "high" side). But, Tom ("Mr." Alternator) will fit the alternator with a smaller pulley (thus turning it faster) if that's an issue for you.
