Alternator Power on 2000 Tacoma w/3.4
Old Feb 14, 2005 | 08:43 AM
fjefman's Avatar
Hey Guys and Gals,
I'm thinking about adding an accessory battery to my Tacoma. I know I need a battery isolator and know a guys how has an extra 90 amp alternator he is willing to part with for cheap. I'm assuming the stock alternator on the Toys is less than 90 amps and this isolator will work. Anybody know for sure?
Jeff
Old Feb 14, 2005 | 10:15 AM
BajaTaco's Avatar
Originally Posted by fjefman
Hey Guys and Gals,
... know a guys how has an extra 90 amp alternator he is willing to part with for cheap...
Hi Jeff,
I assume that you meant that you know a guy selling a 90 amp isolator? Can you tell us what brand and type? (model number would help). If the isolator is compatible with the Tacoma charging system, then it should work. The FSM indicates that the alternator for the ' 99 Taco is 80 amp. I assume it's the same for a ' 00 model.
Old Feb 15, 2005 | 07:14 AM
fjefman's Avatar
Originally Posted by BajaTaco
Hi Jeff,
Oops, sorry, yes, I meant to say I know a guys selling an extra isolator. I really don't know what brand or model it is but I can find out. I really didn't think it mattered. I assumed that if it is rated for 90 amp and the taco puts out less than that then things will be fine. I'm not to bright with electrical things (pun intended) so can somebody please explain this compatability issue?
Thanks,
Jeff
Old Feb 15, 2005 | 09:40 AM
BajaTaco's Avatar
Thanks,
Jeff
Well, for example, a very popular brand of isolator - SurePower, has some info regarding installation on different vehicles here. I believe you need the Type 2 SurePower isolator which has the provision for a sense line that needs to be hooked up to your alternator. I don't think the Type 1 isolator will work with a Tacoma/4Runner.
Flying91
45
Apr 11, 2024 04:39 PM
redneck17
Oct 29, 2015 09:09 PM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
