Adjusting valves
Old Mar 14, 2003 | 05:34 PM
toyo's Avatar
Adjusting valves
Looking for specifics on adjusting my valves. 87 22re. I know the specs on intake and exhaust, perform when hot. But what I cant remember is the timing mark crap. Somebody please refresh my memory. I havent done a valve adjustment in years.
Old Mar 14, 2003 | 06:07 PM
dmode's Avatar
Here's a place that helped me.
http://www.off-road.com/toyota/tech/...ves/index.html
Old Mar 15, 2003 | 04:38 AM
toyo's Avatar
Does anybody have anymore links to read in regards to adjusting valves?
Old Mar 15, 2003 | 10:41 AM
growinseed's Avatar
The other link is about all you should need. Make sure you have a new valve cover gasket, the four grommet/washers under the cap bolts and since its been a while you might want to get the 'half moon' pulgs that go on the cylinder head to valve cover surface, no need to get a vac/oil leak if there old and brittle. If your having trouble getting the cover off make sure to take the washer/grommets off the bolts they can hold the cover on pretty good. I think the torque for the cap nuts is 15ft.lbs
just did this on my 85 22R a few months ago.
Good luck and happy wrenching
Nathan
Blamalam
Mar 12, 2022 07:34 AM
Jason Webber
Sep 2, 2015 03:30 AM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
razorman8669
Jul 12, 2015 12:13 PM
