Adjusting the mass airflow sensor
Old 06-29-2005, 11:21 AM
.........I just put in a new engine and an FIPK(88 22RE) and was planning to richen the airlow sensor a bit according to the LC Engineering website, but according to the local mechanic that did the gas analyzer test for my warranty card, the thing is all ready running rich???? Any ideas what I should do, seems to run good and gets far better mileage than it used to?? Thanks for your time...............TIM
Old 06-29-2005, 06:05 PM
Beartracker's Avatar
If it's running good and getting better mileage , Leave it alone. JMO. Mike
Old 06-29-2005, 07:00 PM
farmerj's Avatar
Leave it be. All you will do is waste fuel.
If you are looking for more torque, change your cam out. Install larger injectors MAYBE.....
Old 09-29-2005, 11:44 PM
bob200587's Avatar
doin that ruined my O2 sensor.
Old 09-30-2005, 06:51 PM
Fahrenheit 451's Avatar
Check and adjust the TPS, clean the o2 sensor, make sure timing and all that is set up right first. Running rich isn't a good thing.
If you are in a smog controlled area, don't touch the MAF. My understanding, and I could be wrong, is that a tampered with seal on a the MAF is a guaranteed way to flunk emissions testing.
Blamalam
03-12-2022 07:34 AM
jetpilot
08-15-2015 06:48 AM
Dennisx2
08-10-2015 06:48 AM
rjtrials
08-06-2015 07:25 PM
Dennisx2
08-04-2015 01:26 PM
Quick Reply: Adjusting the mass airflow sensor
