99 4runner clutch fan
Any videos showing how to take the dang thing off? Just got a new fan clutch today and would like to do it myself vs. taking it to a shop!
Don't know of a video other than this
, but it's simply loosen the belt, remove fan shroud (may not need to if enough clearance), and remove the 4 nuts holding the fan clutch to the fan pulley. A long box end wrench works for me on those 12mm nuts.
I generally drain a bit of coolant and remove one end of the upper radiator hose so the fan is easy to lift out. Once it's out, the fan is attached to the clutch with 4 nuts.
The first page of this tutorial may help.
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
09-04-2015 09:27 AM
