98 Tacoma 2RZ motor info
Old 12-15-2003, 04:08 PM
barkeywayne's Avatar
After many years and a million-odd miles of 70's/80's 20R & 22R's I recently purchased a 98 Tacoma 2WD XCab with the 2RZ 2.4L motor. I was wondering if there are any known weaknesses in this motor and how the cam(s) are driven (belt, gear, chain) and what the replacement interval is for the camdrive system? It has 67K miles on it now and if my previous Toyo pickup history is any indication I hope to see at least 250K on it while I own it. Thanks!
Old 12-15-2003, 04:30 PM
amusement's Avatar
2.4L has a chain driven cam.
I had 135K on my old 95 Taco before I sold it.
lessons learned from my 2.4
Do not use any PTFE or teflon oil additives
I put slick 50 and it built up over time ruining the engine.
I am unaware of any weakness. It's a very solid I-4.
Old 12-16-2003, 07:30 AM
I have never run any oil additives, what kind of problems did they cause? I am running Cast 10W40 semi-synthetic in the 98 now. Did you ever change your timing chain in that 135K? Glad to hear the 2RZ is another good I-4, I would hope Toyota didn't replace the near bulletproof 22R's with a dud.
Old 12-16-2003, 09:36 AM
amusement's Avatar
PTFE builds up on the cylinder walls and rings, valve guides and rods and bearings resulting in Teflon sludge. The sludge acts as a shield and creates abnormal wear.
Castrol is one of the best (if not the best) synthetic oils on the market. Many Yota members use it religiously
I sold the Taco @ 135K miles. There were no issues with the timing chain . The former Taco had no ABS and that really sucked. Breaking was horrible it felt like all drums. Later this year, I will buy a used 2wd Taco with a 2.7L I-4 to be my daily driver. Both 2.4 and 2.7 are great four bangers
, Amusement
Old 12-16-2003, 09:59 AM
That's interesting about the oil additives, I have always been a little leery of them. I have always been a Castrol fan and decided to try the Syntec blend on this truck and am planning on staying with it. I've been getting anywhere from 26-28 mpg with the 2.4L/5 speed combo. Good luck with your used truck hunt, I bought this 98 for $5,750 with 65K miles and in excellent condition. I think I got a deal but we'll see how I feel in a few years.
Flying91
45
04-11-2024 04:39 PM
the1998sr5
15
07-14-2020 08:35 PM
94whiterunner
07-12-2015 07:15 PM
Cplmike
07-08-2015 08:47 PM
AaronM
07-08-2015 07:15 PM
Quick Reply: 98 Tacoma 2RZ motor info
