96 4runner run ruff under load
Old 03-06-2012, 11:16 AM
Jay1's Avatar
My 4runner runs fine under normal driving. But you put a load on it and the engine shutters. Like drive up at steep hill or using lots of gas pedal. I already tryed to clean the maf sensor.
Old 03-06-2012, 11:29 AM
jrock08's Avatar
I would say your best place to start it by checking codes, even if the cel is not on. That will hopefully give you an idea of where to dig in.
Old 03-06-2012, 11:33 AM
9erfaithful's Avatar
Try checking the pressure regulator. Might be the issue
Old 03-06-2012, 11:54 AM
Jay1's Avatar
I have only gotten a cylinder 3 misfire code. It's only appeared once.
Old 03-06-2012, 11:57 AM
Jay1's Avatar
I also did new spark plugs hoping it would help. It did make it run a little better.
Old 03-06-2012, 12:09 PM
jrock08's Avatar
Did you ever diagnose the cylinder 3 misfire and see what might have thrown that code?
Old 03-06-2012, 12:14 PM
totally a bro
Staff
vital22re's Avatar
what plugs did you use? Have you replaced the fuel filter? hows the engine compresion? The early model fuel injectors for the 3.4 had problems and were known to fail.
Old 03-06-2012, 12:30 PM
Jay1's Avatar
I used ngk plugs. Haven't done fuel filter yet. I havent figured out what the misfire was yet.
Old 03-06-2012, 01:42 PM
jrock08's Avatar
I would begin trying to see if you still have the misfire. I'm assuming its a v6 so it may only be running on 5 cylinders but under a load is the only time its really noticeable. I would start by pulling plug wires. If it is in fact misfiring, that could lead you to diagnosis (ie. faulty fuel injector, fouled spark, burnt valve, etc.)
Old 03-06-2012, 03:03 PM
Jay1's Avatar
I did the driver side 3 and the rpm lowered with each one. I could only check the rear one on the passenger side because the air cleaner tube is in the way of pulling the wires off.
Old 03-06-2012, 06:17 PM
jrock08's Avatar
If I'm not mistaken I believe the cylinders are numbered like this:
5 6
3 4
1 2
Front
So, if I were you I would at least find a way to pull #3 plug wire just to rule it out since its an easy test. Search this forum for an easy way to get to those plug wires. If I happen to run across a good thread I'll post it on here.
Old 03-07-2012, 01:48 PM
Jay1's Avatar
Im going to try and check the other 2 cylinders tonight.
Old 03-08-2012, 09:43 AM
Jay1's Avatar
Here's what I have found so far.
-primary coil resistance cold .67-1.05 ohms
3-1.3 ohm
2-1.5 ohm
1-1.5 ohm
-secondary coil resistance cold 9.3-16.0 ohms
3-13.84 ohms
2-19.48 ohms
1-12.58 ohms
- compression 145-218
5-155. 6-not done
3-145. 4-not done
1-155. 2-156
I don't do cylinder 4 and 6 because my compression tool was giving me problems.
Old 03-09-2012, 05:54 AM
Jay1's Avatar
Can I replace one coil pack or should I replace all 3 of them?
Old 03-09-2012, 02:15 PM
tunnelmotor99's Avatar
I see you replaced the spark plugs, but you should also replace the wires...this is a classic symptom of bad wires. Also make sure the wires are in their proper clips and not touching any metal surfaces.
Old 03-10-2012, 08:40 AM
Jay1's Avatar
I didn't replace the wires yet. I plan to buy wires and a fuel filter on this coming Friday. I have one new coil coming because the number 3 cylinder is out of spec.
Old 03-10-2012, 08:51 AM
PismoJoe's Avatar
I doubt its a coil, since they are paired. The misfire would be in 2 cylinders intermittently if this was the case.
You should have swapped coils to see if the misfire would follow, checking resistances won't tell you the full story. Plus this is way easier, but I see you ordered a coil. Throwing parts at something just costs you money.
Fuel filter is not the issue, a clogged filter will never cause solely one cylinder to misfire.
You could have a fouled plug, so swap a new one in #3 and see if the misfire continues. Just make sure they are double grounded plugs. Vitaly had a good suggestion about it being an injector. I use this Injector Inspector which works really well. Other causes would be a cracked head, pay attention to if it misses more cold or hot. Your compression looks good though from the ones you measured, but do the rest. I don't know if you have access to a descent scan tool to check misfire count at idle, but this would be helpful. Wires would be a good call as well. That's pretty much all your options to cause this issue.
Old 03-10-2012, 11:29 AM
Jay1's Avatar
The problem happens warm or cold. You can feel it at low Rpms but you really notice it at more then half throttle. It sputters and and won't gain any rpm.
Old 03-10-2012, 02:05 PM
Jay1's Avatar
I switch the coil with the number one coil. It runs better but it still spudders under load. Couldn't get the check engine light to come on. I'm going to try and switch the number 3 spark plug when I get home and see what that does.
Old 03-13-2012, 09:11 AM
Jay1's Avatar
I put the new coil in the 4runner this morning andirons runs like it should. Thanks for the help everyone.
jennygirl
11-17-2015 11:24 AM
Peach
07-03-2015 09:30 AM
Badger62811
06-26-2015 09:26 PM
zytra
06-24-2015 08:14 AM
ShaunKris
06-17-2015 04:33 PM
Quick Reply: 96 4runner run ruff under load
