92 to 94 engine swap - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-20-2005, 07:03 PM   #1 (permalink)
peterng's Avatar
day,
I'm looking into this a little to late but hopefully not too late.
I bought a 94 pickup jt4rn13p5r7064964, no engine, good remainder of vehicle
I have a 92 pickup that starts jt4rn01p, good engine, body shot
where do I look for info to try to ensure myself that both trucks have the same transmission, that's the only thing I can think of that could cause a problem with the engine swap.
Any other considerations? I'll consider taking the ECU to the 94 but I am most concerned with the tranny, clutch plate diameter? I hear they may have gone to a larger clutch plate in 93 which likely won't mate with the flywheel on the 94?
Anyone with some experience with this wouldhelp a lot !
Thanks,
Pete
peterng is offline
Old 10-20-2005, 10:38 PM   #2 (permalink)
kyle_22r's Avatar
you don't need model numbers to figure those things out...
though i'm assuming they're the 22R-E engine, from the "RN" in the model code...
if we're talking manual trannies here, the clutch and flywheel were upgraded in 1992, so you should be fine. if you have manual hubs on both of them, the tranny is a W56, and even then, any manual isn't gonna make a difference.
only thing is that in '93 or so they went to an electric speed sensor rather than a speedometer cable so you'd have to swap the sensor in or just bolt on your transfer case if you're swapping trannies. the ECU isn't going to make a difference between manual transmissions.
the easiest, most surefire way of swapping in a different year 22R-E is to just strip the engine down to a long block and bolt on the intake manifold of the newer truck. however, between '92 and '94 the ECU and harness are probably the same.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Engine swap from 90 to 92? mike92runnerSR5 86-95 Trucks & 4Runners 19 04-19-2007 06:07 PM
94 4runner engine swap onesimpleman 86-95 Trucks & 4Runners 4 05-03-2006 05:41 PM
92 toy engine swap 89 rebuild rose 86-95 Trucks & 4Runners 34 01-04-2006 06:08 PM
94 22re looking to do engine swap to a 3.0 dbranco 95.5-2004 Tacomas & 96-2002 4Runners 11 07-21-2005 07:11 PM
'94 4-runner engine swap bulldog79 95.5-2004 Tacomas & 96-2002 4Runners 8 05-13-2004 10:55 AM
2009 InternetBrands, Inc.
