315s on 4.10s?
Big difference for me from 265 to 285. Another good difference between alloys to steelies. No difference in acceleration from 285 steelies to 315 steelies. Only change I noticed was braking distance and decreased gas mileage and a smaller penis.
#26
wow i didnt know theres so many of 3rd gen 4Runner on 315s. im still new to yotatech!
#28
Climbed under tonight. Had a friend watch my tire. Jacked up one side and started. Rotated the driveshaft 41 to the tire 20. I guess my door panel is right, 4.10's. So...I supposed I'm clear to run 285's.
#33
If not, you will do one or more of the following.
1. Completely strip the gearing in your transfer case- WAY more expensive than a front re-gear.
2. Completely strip either the front or rear diff gears- Same cost as a regear.
3. Snap ujoints, axles, etc.- possibly cheaper than regear, unless you are completely stranded out somewhere, and have to get a tow.
I understand the need to do things on a budget. I'm sorry, but you simply CANNOT run different gear ratios. Suck it up and get both done, or leave both alone.
#37
if you cant get the front done, just dont even bother putting it in 4wd.
Neliconcept did that, except he bought an already setup 4.56 front diff and had to get the rear done, he just opted for a 4.56 arb from inchworm.
even though i do not like 4wparts, they do setup gears. but id look for a more professional shop around town that would be more reliable and has a better knowledge of r&p setups
FS[MidAtl]: fZJ80 9.5" rear axles w/ e-lockers complete
I8URSVT
10-05-2015 07:23 PM
FS[PacSouthWest]: 8-Inch Axle, '97 4R, 4.10, Drum to Drum-Complete
SharpStick
08-29-2015 12:59 PM
FS[NorAtl]: Elocker 3rd with motor complete
mtb_taco
08-20-2015 12:16 PM
