| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
3.4L swap wont stay running need HELP!!
__________________
Building back yard supercars since 2003 . Current Projects: 3.4L Turbo V6 4runner 3.4L Turbo V6 TRD2000 MR2 3.4L Turbo V6 Sleeper MR2 2.5L RB25 Powered S13 Nissan 4.0L 1UZ-FE V8 MR2 axelsnapper Last edited by node; 03-09-2005 at 03:17 PM. |
#2 (permalink) |
When I put my engine in it did the same thing. I resolved the issue by checking the distributor. Make sure your engine is at top dead center and put the dist to cylinder 1.
__________________
1995 4Runner Limited Edition 4x4. 95 Runner. Pro Comp 4" Lift... That's it for now. SOLD 2005 92 Toyota Truck. Sold 2005 TX4Roc.com |
#3 (permalink) |
3.4's dont got distrubutors. Im confused?
__________________
02 4runner conversion complete! |
#4 (permalink) | |
Quote:
__________________
#5 (permalink) |
Nope its distributor less. It really is getting to the point where Im willing to buy another ECU just to see if thats what is messed up. Its not running long enough to set any usefull trouble codes either so im pretty much stuck.
__________________
Building back yard supercars since 2003 . Current Projects: 3.4L Turbo V6 4runner 3.4L Turbo V6 TRD2000 MR2 3.4L Turbo V6 Sleeper MR2 2.5L RB25 Powered S13 Nissan 4.0L 1UZ-FE V8 MR2 axelsnapper |
#6 (permalink) |
Well like I said I have a 3.0 in both my runner and my truck. My truck is in the shop as we speak getting a new ECU. It did the same thing too. It wouldn't start. Then it would start. The guys at the shop had it for two days before they decided to replace that. So give it a try, you can always take it back if it doesn't work.
__________________
#7 (permalink) |
Sounds like "unsniffed" air getting into the intake track. Have you checked the entire intake track from the MAFS to the TB?
__________________
www.rimpainter.com Get your O Gasket Mod Here! My SC'd 4Runner's Profile My YouTube vids |
#8 (permalink) |
when trying to start the engine do you have the intake tube hooked up to the maf?
__________________
89 SR5 p/u 3.0 5 speed, doa cams, downey headers, jacobs igniton, self made isr pipe, electric fan, 14"flowmaster, allpro rear spool, 63"chevys, 4crawler 2"bl, bj spacers, skymanufacturing u-bolt flip & shock tower, ranchos, 1 1/2 square tube bed, aisin hubs, 35x10.5x15 super swamper boggers.....For ever a work in progress 2000 Tundra SR5 V8 4x4 Bone stock DD/Tow Rig |
#9 (permalink) |
Does exactly the same thing regardless of weather the MAF is hooked up or not, attached to the intake or not. No matter what I do its starts and dies EXACTLY the same. My first thought was the MAF too, thats why I messed around with it. Its a brand new sensor though
![]() No leaks to speak of in the intake tract. It will still get the plugs all wet even if I remove the sensor from the pipe so that no flow is going across it, so somthing else is going on.
__________________
Building back yard supercars since 2003 . Current Projects: 3.4L Turbo V6 4runner 3.4L Turbo V6 TRD2000 MR2 3.4L Turbo V6 Sleeper MR2 2.5L RB25 Powered S13 Nissan 4.0L 1UZ-FE V8 MR2 axelsnapper Last edited by node; 03-09-2005 at 03:45 PM. |
#10 (permalink) |
did you reset the ecu?
__________________
#11 (permalink) |
Could the IGF signal not be getting back to the ECU? How can I check that? Ummm reset the ECU?
I dissconnected the battery many times if thats what your asking. If the ECU goies into protection mode all you have to do is turn the key off and back on right? that would explain why it dosent start unless I turn the key off.
__________________
#12 (permalink) |
Another couple of things. I checked the timing belt and all is well, so it hasnt jumped timing. Base timing should all be ok.
__________________
#13 (permalink) | |
Quote:
__________________
Jay 98 X-Cab Tacoma 3.4L Manual Trans. | TRD Fender Flares | Weld Wheels w/ 31 x 10.5's Jason Larsen Master Diagnostic Technician - Beaverton Toyota (Portland, Oregon) Wendsday - Saturday by appointment only. (503)626-7200 (ask for me by name) |
#14 (permalink) |
Two things:
1) Checked Compression? 2) Unplug one coil at a time. Which is the effected cylinders? (Fires 2 cylinders at same time)
__________________
#15 (permalink) | |
Sponsoring Member
Quote:
The only other thing I can think of is an echo of what Christian said - there's a leak in the intake path. What about the TB gasket? I know that I've put a couple on "wrong" and had pretty similar symptoms. The intake path is pretty sensitive...
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#16 (permalink) |
Do you have the same year ECU as you do motor?
Do you have the OBD system functional as well? OBD would be the best place to look and see what all the sensors are seeing and hopefully pinpoint the problem much quicker.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#17 (permalink) |
Thanks guys you seem to have lead me in the right direction. I traced my MAF wires out to the plug at the ECU and guess what, they are in a different location than it shows in the FSM? The wire harness IS from a 96 4runner so I have no idea why the pins would be moved around. The ECU is from a 98 so im gussing that some of the very early models of 96 were not compatible. Thanks again toyota :/
Working on the problem now
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| changed plugs and wires now wont stay running | Onimacus | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 04-19-2006 08:20 AM |
| 91 4Runner 22RE Starts but wont stay running. | AstroVannin | 86-95 Trucks & 4Runners | 2 | 12-05-2005 07:30 PM |
| 91 4Runner 22RE Starts but wont stay running. PLEASE HELP! | AstroVannin | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 11-27-2005 04:22 PM |
| help my truck wont STAY running | sniper95688 | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 02-23-2005 03:17 PM |
| yota wont stay running | Mudfreak | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 09-08-2004 07:22 AM |
