2nd Gen Rear Lift ?
2nd Gen Rear Lift ?
I know this question has been asked a million times but, when adding a 1.5 inch rear spring lift to a 2nd gen. (1994) 4-Runner, will I need to change out the brake lines? And do they come with the Downey kit?
Thanks!
Thanks!
The brake line should cover it. I would recommend getting a new one though. It's just one line in the rear. Use a 10mm wrench when you try to get it off. If it takes allot of work, you're doing it wrong and you're about to break something. Does it sound like I've done this? I'm not sure if a new break line comes with your kit. Good luck.
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
07-09-2015 02:18 PM
Steezy96yota
07-06-2015 10:00 AM
