2nd gen problem
Old 11-22-2003, 07:43 PM
miketerrizzi's Avatar
2nd gen problem
i got my SR5 used and it was missing the center console and i replaced it, but i think it is missing a switch because underneath the center console there are 3 plugs ,1 for window control and one for the rear heat and 1 extra green plug, does anyone know what this goes to? I have rummaged around at my junkyard and all the 4runners dont have interiors, so i have no idea what it goes to. And also has anyones window switch in the console not work? A friend and me took apart my rear plastic and found out that all the wire that go to the switch are connected but we think the power window moduale is broken, anyone else have a similar problem?
Old 11-22-2003, 07:57 PM
Cebby's Avatar
Mine has a rear window lock switch. Used to keep the rear window from being accidentally rolled down. Helpful when the cargo area is packed up to the roof..
Old 11-22-2003, 08:24 PM
the_supernerd's Avatar
Try going to http://www.autozone.com and clicking on "Repair Info." You can get specific wiring diragrams for your vehicle.
Old 11-23-2003, 07:24 AM
thanks dude i found a electrical map and found out that the green plug is for the window lock, even tho i dont have the switch, i jumped the wire and my rear window switch now works, thanks bunchs
06-01-2021 01:51 PM
tpd143
07-07-2015 09:06 AM
Steezy96yota
07-06-2015 10:00 AM
coryc85
07-06-2015 04:07 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 2nd gen problem
