22RE Spark Plugs?
As in these V-Power plugs (bottom of screen)? So you suggest OEM over that platinum or iridium stuff?
the plat or irids arent going to give your truck any better performance over the ngk v-power..... the ngk v-power or some denso one is actually what my 1985 Toyota FSM lists as an oem replacement
Unless your vehicle came with platinum or iridium plugs, don't use them. Their systems are designed with the higher voltage requirements of these plugs.
Originally Posted by YotaTruck1986
NGK.com says their number is BPR5EY.
88runnergomas
07-09-2015 01:12 PM
