| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22RE Idle Issue
#2 (permalink) |
the thermostat opening has nothing to do with the idle. it sounds like your TPS might be out of whack.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
#3 (permalink) |
I think Kyle is right on. Check your TPS (Throttle Position Sensor). Go here and find out how.
__________________
~ Joe ~ '89 4WD Pickup, Std Cab, 22RE, W56, 4.10's {REPAIRS} Head Gasket, Timing Chain Guides, Water Pump, Alternator {MODS} Flatbed, Turn/Parking Light, SR5 Cluster, SR5 Lighter, SR5 Clock, 750W Inverter {ACCESSORIES} 33x12.5 on 15x8's (no lift), Radar Detector, CB, Contico Tool Box, Pilot Driving Lights, Fiamm Freeway Blaster {WAITING} Portable Air Tank, Big 3, Hood Scoop |
#4 (permalink) |
Ok, thanks for the replies. I checked the TPS and all of the resistance values were within the range specified in the service manual and on 4 crawlers instructions. Any other ideas?
#5 (permalink) |
I'm tapped for ideas, but did you ever get this taken care of? I'm curious as to what you found.
__________________
#6 (permalink) |
It was a bad head gasket letting combustion gasses into the cooling system. When an air pocket would pass the coolant temp sensor, the idle would rise until the computer would cut off the fuel until it came back down, causing the surging. This seemed to happen mainly during warm-up at first, but as the problem got worse, it would happen after warm-up also. This vehicle only has 134,000 miles and was meticulously maintained from day one, with a coolant change done every other year. Why are these 22RE's so prone to head gasket failure? I see many others on this board that have had head gasket and timing chain failures on 22RE's. I've had 4.0L Jeeps for years with as many as 275,000 miles and never had headgasket or timing chain failures. Maybe Toyota should use cast iron heads like Jeep does instead of cheaping out and using aluminum. This will be my last Toyota. I do appreciate the help I received from the others here and just wanted to end with a "Thank You".
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Idle Issue | JEBSR5 | 86-95 Trucks & 4Runners | 25 | 03-16-2007 06:05 PM |
| Idle issue | Sonofmayhem | 86-95 Trucks & 4Runners | 40 | 02-05-2007 06:50 PM |
| 22RE timing and idle issue | rdlsz24 | 86-95 Trucks & 4Runners | 4 | 01-20-2007 08:33 AM |
| 22RE idle issue? | dave151 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 10-24-2005 12:48 PM |
| idle issue | jayson161 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 12-13-2004 08:57 PM |
