| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22r carb help.
#2 (permalink) |
sounds like it was working properly before, though your warm idle sounds a little low(goal is about 850-900RPM). the high idle is the choke -- maybe the choke is sticking? mine will sometimes stick on the high idle until i slap the gas a few times which turns the choke off
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
#3 (permalink) |
thats what i had to do but now it wont un stick except if i do one thing if i am driving kinda slow about 20 or so and put it in 2nd. and slap the gas and make the truck kinda jump and it fixed it one i pushed int he clutch then let out and pushed back in a few minutes later and it went back up. something has got to be sticking
#4 (permalink) |
check your return spring on the carb linkage? grab onto the lever that opens the throttle on the carb and pull it back and see if the idle speed drops. if it does, it's probably the spring
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| FS! built 22r, weber carb, holley carb, and camden supercharger | utah | The Classifieds GraveYard | 4 | 05-15-2007 05:27 PM |
| 22r carb troubles | jackedmini | General Vehicle Related Topics (Non Year Related) | 3 | 04-09-2007 07:25 PM |
| 22r carb | Leonardo Muniz | The Classifieds GraveYard | 4 | 01-02-2007 11:08 AM |
| 22r carb help! | knottshawk | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 12-05-2005 09:42 PM |
| 22r carb | Calvin baxter | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 09-27-2005 11:24 PM |
