2001 4Runner Disable DRL - High Beam Indicator
Old 05-12-2004, 11:14 AM
PhxRunner's Avatar
I have read here and other places about the process of disabling the DRL on a 2001. I have also read that doing so will give you a faulty high beam indicator light.
Has this intermittant problem been resolved and if so, how? I would like to disable mine but don't want the high beam indicator to flicker on and off.
No flames about why I want to disable please.
Old 05-13-2004, 05:11 AM
rwmorrisonjr's Avatar
Location: Home: Aurora, CO; Work: The People's Republic of Denver
Welcome to the board. Do a quick search as this topic has been discussed before. It varies from truck to truck on whether you'll have this problem or not. Eventually it does go away as the relay burns out but doesn't effect the working of the lights.
Old 05-13-2004, 07:45 AM
PhxRunner's Avatar
I cut the wire last night and I've got no high-beam indicator light flashing. Good.
My next project is to upgrade the horn this weekend.
Old 12-25-2004, 06:06 PM
calrockx's Avatar
so this problem goes away? yeah it's not serious, but kinda annoying.
my high beam indicator goes on like normal when the highs are on, but when the headlights are off, it shows up, not as strong as when the highs are on, but it faintly shows up.
Old 01-19-2005, 06:06 PM
calrockx's Avatar
i guess it doesn't go away.
Old 01-19-2005, 06:52 PM
aowRS's Avatar
I cut the correct wire a month after buying the truck - no problems since.
As for the horn upgrade, I'm not sure what year you have, but the stock horns on my 2001 sound perfect. I think Toyota may have changed to the more 'American' sounding horns in '00 or '01. Check it out, as is then should be an easy plug and play swap.
Andreas
Old 01-19-2005, 07:02 PM
kevin444's Avatar
my 00's were the wussy meep meep ones. I bought 2 fiamm high tones and was happy! Direct replacement.
Old 01-19-2005, 07:16 PM
lee
lee's Avatar
i really have no issues with my horn... theyre not at all meep meep -ish. did they change the horn in 01 then?
Old 01-19-2005, 07:18 PM
aowRS's Avatar
Lee,
Sounds like they may have. Mine sounds great. Very unlike the "Meep-Meep" horn on my wife's '00 Outback.
Andreas
icentropy
09-16-2020 02:47 PM
MTLroadierunner
07-15-2015 12:58 PM
Nickdigg
07-07-2015 06:04 AM
musashi86
California SoCal
07-07-2015 03:31 AM
Quick Reply: 2001 4Runner Disable DRL - High Beam Indicator
