2000 Limited Flare Trim Part No.???
Old 10-08-2007, 09:51 AM
dok4runner's Avatar
Does anyone know the part number for te 2000 limited flare trim (front/Rear Passenger/Driver side)? It is basically the rubber strip that goes in between the flare and the body to potect from water going inside the flares.
I am looking for a blank ones.
Thanks.....
Old 10-09-2007, 12:00 AM
4RUN-GT's Avatar
Don't know if this will help, but...
Here's the part numbers for the pads I purchased in '99. I've heard Toyota did some renumbering of their part numbers. Hopefully someone has the updated info. Keep in mind these part numbers are for the Black Pads. They come in a bunch of different colors. Use these part numbers mainly for reference, and hopefully it'll get you steered in the in the right direction.
Pad, Front wheel 53853-35020(Same for Dr & Pass Side)
Pad, Quarter Panel 75659-35010( " " " " " " )
Protector, Rocker 75861-35010( " " " " " " )
Old 10-10-2007, 03:54 PM
Whitey13's Avatar
Thanks.....
bump. I have the same question
Old 10-11-2007, 04:35 AM
KZN185W's Avatar
75691-35010 front RH
75692-35010 front LH
still looking for the ones for the rear
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
09-04-2015 09:27 AM
Avenged
07-09-2015 07:55 AM
Cplmike
07-08-2015 08:47 PM
Quick Reply: 2000 Limited Flare Trim Part No.???
