2.7 gas mileage?
Old 03-01-2003, 04:10 PM
NHTacoma's Avatar
Unhappy 2.7 gas mileage?
Hi everyone. I've had my '99 Tacoma 4x4, 2.7, with 31" and about 90K miles for a few months now. I'm getting much worse gas mileage than I was expecting. I'm lucky to get 17 mpg, but 15 is pretty common. I'm not using the AC, the hubs are unlocked, and I'm shifting pretty short. Is this reasonable? If not, any ideas what I should check?
Thanks,
Tom
Old 03-01-2003, 04:20 PM
Nolan's Avatar
That is pretty bad, i have a 2.7L in my 96 4runner with 106k miles, "sprited" city driving i get 18-19 and highway 21-22 or better.
Old 03-01-2003, 04:33 PM
CLin9383's Avatar
yah, that's pretty bad, in the city i get like 15, but highway i go around 80 and get 19 per..and i have a 1996 3.4 with 90k miles
Old 03-01-2003, 07:22 PM
sschaefer3's Avatar
I could go 350 miles with the 18 gallon tank with 31's, now with 33's I can go 300 miles on 18 gallons. But that is with 5.29's & Manual Hubs.
Old 03-01-2003, 09:24 PM
Nolan's Avatar
hey steve, do all 4runners have 18 gallon tanks? The most I have ever put in is 15 gallons and that was with me driving about 20 miles with the fuel light on.
Old 03-01-2003, 11:22 PM
jx94148's Avatar
Older ones have 15-16 gallon tanks depending on how much of the filler neck you use and how much sediment is in your tank. You'd be suprised to see what came out of a '94 Jeep fuel tank I recently bought. At least 1/3 of a gallon of mudlike crap, almost 1/2 inch deep away from the pump and strainer.
I'd be pissed if I was only getting 15 MPG. I still get 19 on 32" tires, 4.30 gears, 202000 miles. When I first got my truck and it had no bed cap, tailgate down to reduce drag, and 28" tires I got 26 MPG on mostly level highway at 60 MPH.
I'd expect the fancy new junk to get at least 22 MPG at 65 MPH on a standard cab truck. I'd want 0-60 times under 12 seconds on a stock one also.
22RE swap anyone??
Edit: Short shifting dosen't necessairly mean less fuel used. It usually means more unburned fuel getting to the catalytic converter where it's wasted. This type of motor likes to rev kinda high where it makes its best torque. At least I have found this to be true on my old carbureated junk. I can't speak from experience on the 2.7 liter.
Old 03-02-2003, 01:05 AM
butnut's Avatar
I get a steady 21mpg with freeway/city driving. I have a heavy foot with the 2.7 It's an auto tranny, AC is never off. I was hoping to do better as I heard so V6ers get higher numbers...maybe a SC would help.
Old 03-02-2003, 06:42 AM
NHTacoma's Avatar
Yeah, that's pretty much what I figured. Anyone have any idea what could be causing the problem?
Thanks a bunch, guys.
Tom
Old 03-02-2003, 08:47 AM
dhancali's Avatar
I get around 15 mpg. But I mainly do stop and go street driving with my car. Maybe I should turn the o/d off...nahh. Any suggestions, or modifications I could do to get better mpg. I just put a Magnaflow in recently and am going to compare it. Also, those getting more, what was your mpg before you did any modifications to your cars?
David
Old 03-02-2003, 08:51 AM
rowan's Avatar
yeah i get at least 350 miles to a 18 gallon tank.
maybe you have a lot of weight in the back? hahahah. i dont know.
maybe just take it in for a tune up.
Old 03-02-2003, 06:40 PM
sschaefer3's Avatar
As far as I know they all have 18 gallon tanks. I have the "new & improved" 1999 fuel gauge and sender. Swaped that out in 2001 under a TSB. I could only add 15 before that.
Old 03-02-2003, 07:50 PM
Nolan's Avatar
Now the question is, do I go another 60 miles after the fuel light comes on? HaHaHa I don't know if I am that brave.
Old 03-03-2003, 09:38 AM
SLOYOTA's Avatar
I get 23-24 mpg. My runner is stock except for the 265/75-16 rims and tires.
Old 03-03-2003, 04:45 PM
martin's Avatar
I have a new 02 Tacoma and have filled up the tank 3 times. I have received 26, 22 and 18 mpg. Mostly highway.
Martin
Old 03-03-2003, 07:37 PM
NHTacoma's Avatar
To address my mileage problem and also a problem with the heat, I just had the cooling system flushed and a new t-stat installed. Hopefully it will make a difference, but I doubt it since the temp always indicated normal. Keeping my fingers crossed, though.
Thanks for all the input, guys. This board rocks.
Tom
Old 03-03-2003, 08:09 PM
94 First Responder's Avatar
I got avg 320miles p/ tank (18.8gals) on my 3.0 5spd and 31s on 10in wheels when I was running those.
Old 03-03-2003, 08:42 PM
atarinaper's Avatar
22RE swap anyone??
LC engineering sells them brand new. really nice ones too.
Old 03-04-2003, 06:12 PM
rowan's Avatar
just a thought - did yours come stock with 31's? maybe you got bigger tires and that is eating at your gas mileage.
i dont know if it would take it down that much though. well good luck.
he's gone
7
12-03-2019 07:08 AM
accuracy
08-30-2015 09:47 PM
raptor510
08-19-2015 02:15 PM
Tacoma1313
08-17-2015 05:44 PM
nonstop
7
08-11-2015 09:26 AM
Quick Reply: 2.7 gas mileage?
