1st signs of auto transmission failure?
Old Nov 21, 2004 | 08:36 AM
Parlos's Avatar
I have a 2002 double cab, supercharged w/ URD fuel upgrade, additional tranny cooler, Procomp lift with 33s. What are the first signs that something might be wrong with my tranny? It seems as in 2nd gear, the truck doesn't want to go when I accelerate to try and pass at low speeds.
Old Nov 21, 2004 | 10:10 AM
yamarocket630's Avatar
The first sign is that it's an auto... :pat:
Seriously, there can be hundreds of signs, it usually starts out by doing something a little bit differently than it did for the last 2,000,000 times.
Old Nov 21, 2004 | 10:43 AM
User 051420's Avatar
Slippage...The first thinig I'd do is get it flushed ASAP..Then, I'd go get a valve body upgrade! You have a lot of power running through that stock tranny. IIRC, Gadget blew his REALLY quickly.
Old Nov 21, 2004 | 05:13 PM
Parlos's Avatar
Slippage is what I'm starting to feel, especially going up hill. Will flushing the tranny and getting the valve body upgrade fix the problem, or only prolonge the inevitable. Should I even try and get it fixed under warranty. My truck only has 35K miles on it. If I flush and do the valve body upgrade and it fails, there's no way that Toyota will fix it under warranty.
Old Nov 21, 2004 | 05:58 PM
jimbo74's Avatar
i have ehard that if your tranny is already in trouble that flushing it is actually worse on it!
Old Nov 21, 2004 | 06:26 PM
GodwinAustin's Avatar
slipping is bad -clunking sounds are also bad - you might also notice a drop in MPG
my brother killed our 1990 Buick Century wagon by driving it for a long time with zero transmission fluid - idiot
that was such a great car....engine still starts it just cant go anywhere
Liadrin
Apr 25, 2022 02:54 PM
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
Liadrin
Sep 1, 2015 06:44 AM
Michael oaks
Jul 27, 2015 11:47 AM
