03 Head Room?
Old 06-04-2003, 10:13 AM
FROSTY
Guest
Posts: n/a
03 Head Room?
Has anybody tried a 03 w/out a sunroof vs. a sunroof? I checked out two local stealers but they just had the sunroof version...I end up looking through the tint and my head hits the top...
no bueno on the sunroof
Old 06-04-2003, 10:18 AM
Hannerhan's Avatar
Without sunroof you have a lot more headroom. I would guess about 2 full inches. It's a big difference.
Old 06-05-2003, 06:50 PM
tank_bmb's Avatar
head room
Did you adjust the seat height?
I'm 6'4" and just bought an '03 SR5 with sunroof, no problem with head room. Just wish the rear view mirror was a little bit higher.
Old 06-05-2003, 08:45 PM
BT17R's Avatar
FROSTY, the brochure says headroom in a sunroof vs. non-sunroof truck is 39.1 vs. 39.7.
tank_bmb, did you adjust the mirror up at both pivots? There's a ball and socket at each end of the mirror arm. First pivot the mirror housing downward at the mirror end so it's pointing towards the floor. Then raise the arm up towards the ceiling at the windshield end, and finally adjust the mirror for best rearward viewing. It'll give a better view in both directions.
Old 06-05-2003, 09:32 PM
keisur's Avatar
yeah, I noticed the headroom issue. my wife has the sunroof and I am used to my runner. when I am driving and I lean forward to readjust the boys or just scoot up in the chair I knock my head into the ceiling. that doesn't happen in my runner. there are a few quirky little things that I don't like about her '03.
Old 06-06-2003, 05:06 AM
tank_bmb's Avatar
adjusting the mirror
Bob,
Looks like what you said will work. However, I tried to adjust the arm and the thing would not budge. It is definitely at the lowest setting. Any suggestions?
Old 06-06-2003, 06:26 AM
BT17R's Avatar
Maybe the SR5 has a different mirror bracket? I just checked mine again and didn't see any friction adjustment anywhere, so it should pivot freely. Unless it's a different bracket for the electronic mirror on the Limited only.
Old 06-06-2003, 06:37 AM
tank_bmb's Avatar
adjusting mirror
It definitely looks like it should be able to move. The back side of the ball joint (side facing windshield) has a pin in it which is limited to vertical movement by a slot. The pin is all the way at the one end of the slot. (meaning it is on the low end).
I was afraid I might break it, but I used enough force that the mirror came off of the mounting bracket. Then plenty with the mirror off.
I'll probably stop by the dealer and check it out.
Old 06-06-2003, 04:15 PM
tank_bmb's Avatar
got it!
I figured I'd give it one more try before going to the dealer.
Took off the mirror and finally got it to budge, it was locked up somehow. Works much better now though.
Much, much better view. Now I can actually see to the right.
Thanks for the tip Bob - probably saved me a wreck.
Badfish740
Diesel Swaps
12-09-2016 06:18 AM
rondogracing
Engine Swaps
16
08-24-2015 03:02 AM
lectric80
08-11-2015 12:02 AM
KBar
08-03-2015 11:12 PM
this_guy
07-31-2015 01:27 PM
Quick Reply: 03 Head Room?
