1984 Toyota Pickup 4x4
Merry Christmas. I got a really nice dash cover from coverall. Lifetime warranty! What!
http://imgur.com/2ccaExZ
It looks great! Did you have to paint it?
#26
pulled the valve cover to unveil the mysterious timing chain... single row plastic guides /;
in decent shape though. head looks good. cleaned the crud out of the valve cover and did the gasket. brake job went about halway good haha. need a booster and master cylinder (landcruiser??) heres the goods. oh and i dropped my seat off at the upholstery shop. i pick it up in two weeks. cant wait
#27
Popped the hood and used my search function. Found this screw that controls my idle and thus, I have fixed my idle. Pretty simple stuff. Now I'm just researching why my engine idles quieter with the reed valve disconnected. Guess I'm going back with that search function... Haha
#31
#33
My brakes are doing some crazy stuff. When I press them in the idle surges about 500 rpms... Checked some vacuum lines and replaced a few ditzy clamps with real clamps and noticed a difference in the brakes.. Next up is replacing the booster, vacuum advance stuff and brake master cylinder. If that doesn't fix it then I'll be confused. Not.... That I already.... Am?
#35
So, while I'm waiting for payday...
If you should ever buy a coverlay dash cover, they give you this glue to use. I think glue is for kindergartners and the like so I went with good velcro from the ol home depot. This is because if I need to remove my dash assembly the glue would make the situation..... STICKY. The ends fit like a glove. No need to secure them as they don't rattle. The only part you really have to meddle with is the center. I put both parts of the Velcro down where I thought they were needed, leaving the adhesive open to interpretation. This helped because I didn't have to line up the Velcro. I used a pair of my girlfriends shoes to wedge the cover down until the Velcro had done it's thing. I'm keeping the glue for arts and crafts.
#36
Staff
That dash overlay made a big difference. Looks 10 times better. I have found perfect dash pads and a short time later they crack and about to give up on factory pads. Glad you posted that.
There is a white valve on the firewall, is fuctioning for your brakes? Booster would be my suspected problem or a vac leak somewhere.
#38
84 Toyota Truck
Hey man nice looking truck.Looks like she needs a little rust repair on bed but all in all a good find.If you're looking for a brake booster i have both a stock single diaphragm and dual diaphragm to upgrade to v-6 front brakes.Pm me if interested.How does the frame look on the truck?Thats usually the first thing to rot out where i live and its hard to find one that hasn't been hacked by someone.I plan on putting a weber 32/36 on my 87 as well,i have the parts just been so cold and we have gotten 4 feet of snow in the past week or so and its gonna snow from today till tuesday.Gotta love it! Good luck with your build.
#39
I got under it before I bought it and looked the whole frame over. It's solid. The bed is in bad shape but it works for now. I will probably shell out the cash for a replacement before trying to repair this one. I can stand in the bed without it giving though. So it's got some work left in it. I think I'm gonna go with a new brake booster and iacv. I like peace of mind. And thanks. Good luck with yours as well!
#40
84 Toyota Truck
Oh and by the way that dash overlay looks awesome! I need to do something with my dash too.Is this a hard plastic or does it have some flex to it?How well do the vents fit back in there openings?Looks great from what i can see!
