Toyota Buggy Tn
Toyota Buggy Tn
I hate to do it but it?s time to sell my buggy to fund a new investment I?m working on. This buggy works very well and is ready to ride right now.
Front Axle:
85 Housing, full gusset with added trusses
HP diff
4.10 gears
Full spool
30 spline Longfield axles
ARP hub studs
Drive flanges
Marlin Diff Armor
Full hydro steering, single ended ram
Rear Axle:
85 Housing
4.10 gears
Disc brakes
Full spool
Marlin Diff Armor
Trans and tcase:
G54 with dual cases
MC07 Marlin adapter
2piece front driveshaft with carrier bearing for flat underbelly
Full belly skid with boat sides
Motor:
Stock 84 22R
Approx 10k since full rebuild
225 Impco Propane Mixer
GM 1-wire alternator
PSC hydraulic pump
Doesn?t leak oil, smoke, or make any noises.
Suspension:
14? 2.0 Fox Air shocks
.375 wall 2? o.d. lower links with R.E. joints
Poly Performance link bracketry
Rear Currie Anti-Rock sway bar
Suspension works and cycles excellent
Tires and wheels
39.5 Iroks on 15x8 DIY beadlocks
Tires are approx 95% tread
Also spare wheel and tire, tire has 100% tread but is tubed
Other stuff:
Kirkey seats
5 point harnesses
Warn RC 9.0 winch
Wilwood clutch and brake masters
Removeable steering wheel
This buggy was completed in May 06 and was probably ridden 15 times since then. I wanted the buggy to be bare bones and as easy to work on as possible. It uses all Toyota parts except for the aftermarket parts listed. There are no frills on it and nothing complicated in it?s design but at the same time works exceptionally well. It is turn key ready to ride right now. I have several spares that I will include with it, driveshaft, axles, ect.
Price is 11k
I also have a 16ft Hurst tag a long trailer that I will include for another $1650. Trailer has been used less than 6 times.
Buggy is located in northeast Tn
Pm for more info
Front Axle:
HP diff
4.10 gears
Full spool
ARP hub studs
Drive flanges
Marlin Diff Armor
Rear Axle:
85 Housing
4.10 gears
Disc brakes
Full spool
Marlin Diff Armor
Trans and tcase:
G54 with dual cases
MC07 Marlin adapter
Motor:
Stock 84 22R
PSC hydraulic pump
Suspension:
Tires and wheels
Other stuff:
Kirkey seats
5 point harnesses
Warn RC 9.0 winch
Price is 11k
Pm for more info
Of course. I will load it up and take you to Callentee, Harlan, or anywhere else fairly close. I would prefer it that way actually. I will stand behind this buggy's capability 100%
09-04-2015 09:27 AM
