Built 22RE Engine
Built 22RE Engine
I have a built 22RE that needs a new home. It's only been in the truck for about two years and runs great, but I'm starting a new project and don't need it anymore. The engine has only seen about 20,000 miles (probably less) since it was installed. I don't know the mileage from when it was installed (it was a used short block) but it was is in great condition, has no leaks and has good compression. Here's a breakdown of what it has and what has been done to it.
Aftermarket parts:
-Downey chrome header w/ down pipe
-Crane high performance cam
-Rockstomper motor mounts
Other items / work performed:
-Timing chain, timing gears and metal backed guides installed when engine was installed along with timing chain cover, oil pump,
-All new gaskets and seals at the same time
-Head was surfaced and re-built
-Injector O-rings / seals replaced last year along with intake manifold gaskets
-Belts replaced a couple months ago
-Only Mobile One synthetic oil used, rockers adjusted at normal intervals
-Includes engine harness, computer and air flow meter
I’m sure I’m forgetting some stuff but that’s most of it
Does NOT include alternator, flywheel, radiator hoses or O2 sensor. Everything else on engine is included, let me know if you have questions regarding what’s included.
I will be pulling the engine from the truck this weekend (Sept. 27, 28), it would be great if someone could pick it up around the same time so that I don’t have to store it. The engine is located in Silverthorne (about 45 minutes from west Denver). I’m looking to get $800.00 for the set-up, which seems more than fair for what’s included and how it runs. If you have questions or are interested you can reach me through PM or phone (970) 485-0364
Jeremiah
Aftermarket parts:
Jeremiah
steve miller
10-10-2015 01:40 AM
skoti89
07-06-2015 07:45 PM
