88 4Runner SAS Rust Free.
Up is my 88 4Runner. The IFS front has been replaced with a solid axle from an 85 4x4. All suspension components are from All Pro off road. The front consists of a spring hanger 5" all pro springs and 2" shackles. The axle has cross drilled rotors and brand new calipers. It also has 1.25" wheel spacers. The front drive shaft is lengthened along with the rear drive shaft. The rear suspension consists of 56" long rear springs and the Ubolt eliminator kit. The rear has chrome alloy axle shafts and a disk brake conversion kit with drilled rotors and new calipers. The front and rear both have 4.88 gears and a detroit locking differential in the rear. The transmission is stock 5 speed with the all-pro transmission emergency brake. It needs new pads on the trans brake. I had the motor rebuilt last summer and have accumulated aproximately 3700 miles on the motor since the rebuild. It is bored .40 over stock. The truck has ice cold a/c. I have a pacesetter header that goes to a flex pipe into a flowmaster muffler that dumps under the rear of the truck. The truck PASSES CALIFORNIA SMOG. Along with the motor the radiator and all components including the Clutch system from the master cylinder and slave cylinder have also have been replaced as well. On the front I have a Steel bumper housing a 10K winch that is about 6 months old that I have NEVER Used. The truck has been off road 4 times in my 7 years of ownership. The truck has Dual Marine batteries. It is on 15x12 einkie rims mounted on 35 x 12.5 BFG all terrain tires. The tires have about 90% tread left on them. I recently changed out the rear quarter panels to those from an SR5 4runner. The front seats are from a Honda Civic. It has a CD player and the entire interior is Gray. The exterior color is Lime Green. The truck was painted in July of 2004.
The body is straight with minor dings but remember this truck is 20 Years old and came from the Las Vegas Desert so it is RUST FREE. The truck scores over 700+ on an RTI ramp and I will send you a link to photos of it flexability.
EXTRA PARTS::::::
You will get 5 more tires and wheels they are (4) BFG Mud terrains 35 x 12.5 mounted on 15 x 10 5 spoke aluminum ultra wheels. You will get an additional rear toyota axle with 4.88 gears installed complete from drum to drum. You will also get another set of 4.88 gears completed (that is 2 sets of 4.88 geared 3rd members. I also have a top shifting transfer case that was ment for my Dual case project I never Got to.The transfer case was inspected and traded to my by a trans tech who needed an entire transmission. I also have 2 more front and rear driveshafts with CV joints. I also have numerous Head and tail light assmeblies extra alternators, ignitor coil packs and numerous other toyota parts to go with the truck.
$7200.00 OBO
James 954 - 296 -2745
EXTRA PARTS::::::
$7200.00 OBO
09-04-2015 09:27 AM
