1994 FZJ80 Front axle **SOLD**
Old 03-17-2014, 12:49 PM
04sport4x4's Avatar
SOLD
Front axle from a 1994 Toyota Land Cruiser FZJ80 non elocker, hi pinion 4.10 gears. Complete except for the brake calipers. Rotors nearly new with just surface rust. All ABS sensors and connectors uncut. Knuckles not leaking. Includes both the tie rod and drag link. About 220k on the truck it was pulled from. I did not see it run.
$575 obo
Local pickup only
Location SoCal 90605
Thanks,
John
Old 03-17-2014, 12:54 PM
blake.nemitz's Avatar
can you put mini truck knuckels on these? if you can i might be interested
Old 03-17-2014, 01:14 PM
04sport4x4's Avatar
The FZJ80 knuckles and balls are larger then the mini truck so these are stronger. The wheel bolt pattern is the same as the mini truck. The axle is 63.5" wide which is a nice improvement over the 85 and earlier axles. Just need to work out your steering.
Old 05-28-2014, 03:22 PM
04sport4x4's Avatar
Still available.
Old 06-25-2014, 12:43 PM
04sport4x4's Avatar
Bump.
Old 07-09-2014, 12:37 PM
04sport4x4's Avatar
Sold...
Flying91
45
04-11-2024 04:39 PM
oldirtydirt
02-23-2020 09:30 AM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
coffey50
07-28-2015 10:55 AM
Quick Reply: 1994 FZJ80 Front axle **SOLD**
