Lift for 35's? 37's?
Old 01-13-2009, 02:30 PM
JD91T's Avatar
Curious what amount of lift would be necessary for a 91 solid axle truck to run 35x12.50's? or maybe even 37x12.50's? Thanks in advance.
-Josh
Old 01-13-2009, 06:17 PM
85TurboRunner's Avatar
I'd say about 16" to 17" maybe even more I'm not sure.
Old 01-13-2009, 06:39 PM
JD91T's Avatar
Geez 16". So... that would take a combination of lift kits. Might just stick w/ the 31's and no lift.
Old 01-13-2009, 06:52 PM
904_runner's Avatar
Is it already sas'd ?
If so what springs are you running?
Old 01-13-2009, 07:26 PM
JD91T's Avatar
No actually it'll be a 91 body on an 85 frame. So I was curious what springs would be necessary? I've been reading through some posts, and it seems like people are running between 4-6" to achieve 35's. That seems a little more do-able.
Old 01-14-2009, 05:06 AM
chad1041's Avatar
dont quote me on this but my friends are runnin bout the same set up as your truck for their boggin truck with 6in sus. 3in body but they are running 38s and 40s i know with 6 on my taco i can run 35s
Old 01-14-2009, 05:12 AM
waskillywabbit's Avatar
Above 35s lift is irrelevant as you will have to tub the firewall and trim other sheet metal.
You can fit 35s on 3" leaf springs if it is SAS'd.
Old 01-14-2009, 06:22 AM
JD91T's Avatar
Thanks for all of your input guys. I was hoping to get it done w/ minimal lift to keep the cg low. 3-6" sounds good. If some wheel/fender/bed trimming is necessary then that'll be fine too.
Dparr2ndgen
09-08-2015 01:06 PM
justdifferentials
09-05-2015 06:52 PM
joeynational
09-05-2015 01:54 PM
matthew138
09-03-2015 08:21 AM
Ryall
09-02-2015 06:48 AM
Quick Reply: Lift for 35's? 37's?
