| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
sbf or sbc????
#2 (permalink) |
Keeping the IFS and swapping in a V8 will be difficult, but can be done. You will want to find the shortest oil pan possible.
Ford will be much easier to fit and give you more room to mount a radiator due to the front mounted distributor. Chev may be a little cheaper for parts Use a ford or chev transmission, the stock 4cy wont last. Gas mileage will suck unless you go with a mild version and EFI.
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
#3 (permalink) |
ok. i was planning on using just a stock motor with no add ons, and where would i go to find a 5-speed and everything else needed for the swap?? and as for the mileage, im not too worried about it.
#4 (permalink) |
Unless you have friends with parts, then a junkyard is your best bet. Do some research on the 'net for manual transmission options, wether it be Ford or Chevy. Popular trannys are SM465, NV4500, T-18.
Here's a good guide of many manual trannys http://www.motivegear.com/tech_info/...nny_guide.html And here is a lot of good engine and trans info http://www.novak-adapt.com/knowledge...ge_gateway.htm
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear Last edited by Adam F; 08-17-2008 at 11:29 AM. |
#5 (permalink) |
I'll plug for the 350 simply because it is cheap, parts are plentiful, and LOTS of people have done it, so there is a lot of info to help you when you run into snags.
Plus, its just a burly motor.
__________________
1987 Mutant 4runner|Slightly Modified|Lacking general build direction -Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail. -Internet Nice Guy |
#6 (permalink) |
my buddy has a 350 he'll sell me, the only thing i need to really find is a transmission, t-case, and everything else needed, and how hard would it be exactly to do a 350 swap???
#7 (permalink) |
and thanks for help and advice so far
#8 (permalink) |
How much money do you have?
__________________
#9 (permalink) |
at the moment nothing.... im awaiting to hear from ,im hoping, my new job by tomorrow or later this week. why do you ask??
#10 (permalink) |
Because....its expensive. I'm assuming you cant fab, so you'll have to buy all your motor mounts and t-case mounts. Headers, exhaust work, radiators, fans, drive shafts, and the list goes on. It is NOT cheap. There are SO many little things that you might not think about that will add up. Trust me, I'm in the middle of a 350 swap myself.
And what about tools? Do you have air tools? Do you have an engine hoist? Do you have an engine stand? Transmission jack? You'll NEED all that to get the job done. And you know the old saying, "if you have to ask, you probably wont/cant/shouldnt" Not trying to burst your bubble, just look at it realisticly. Its not a job your going to get done over the weekend. It will take LOTS of time and LOTS of money.
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear Last edited by Adam F; 08-18-2008 at 08:36 PM. |
#11 (permalink) |
i was thinkin bout a SBC swap for mine,but decided against it, since i bought my truck cuz its a toyota. once you drop a chevy in it, its a chevy in disguise. plus it would handle like a diff truck, i personally like the way mine handles. now im not saying im against it, id love to have one, but not in my truck. maybe a 4runner purchased as a project/crawler/prerunner. trust me, i used to have a chevy with a 350, and they are VERY thirsty, you do NOT want one as a daily driver. ...unless someone is paying for your gas. just ask yourself if its really worth it.
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back. 1988 Toyota P/U 4x4 22re, 1200 miles on the rebuild engine builder .268 cam pioneer CD deck 31x10.50x15 BFG A/T BAJA 100W lights on prerunner bumper KC Daylighters 100W rancho rs5000 MUD IS A VALID PAINT JOB! If not living life to the fullest, why live it? my trucks official buildup thread |
#12 (permalink) |
the tools i have, i have some experience in modifying and im well aware about time, i have a 1960 chrysler that needs brake work, i have a hoist stand, all the stuff neede todo the work, and that chrysler was my daily driver my senior year of highschool and that has a 383 and that was a thirsty motor, and before that i drove a 74 chevelle with a 350 so i know how thirsty they can be, so i ended up driving a 1985 ford f250 with a straight six and a 4 speed, and after that i bought my first yota, a 92 pickup, two wheel drive, 22re 5spd manual steering, nothing fancy, than i got rearended just this january, the truck was totalled and but the motor was still good so i pulled it and the trans, so i looked for another toyota with a bad motor, i found it for 300 bucks, 87 4runner with a custom lift, it was chillin in a corn field, it had a rod knock, so i replaced the motor and ran fine, than a couple months later it started missing on cylinder 2, i replaced the injectors, didnt work, i left the upper intake off for a week, put it back together it ran fine, two days later i was back to where i was, no one has been able to help me out so i decided to do the swap for a carbuerated 350
#13 (permalink) |
Good luck, but did you ever think about a 4.3L chevy swap?
You can keep all the other toy stuff in the drive train. Phil
__________________
1988 4 Runner w/225,XXX miles, 3.slow V6. A/T. 4.10s?-(G292 code) and power everything else that still works, except someone broke off my electric antenna. 1.25" BL. Used Marlin Crawler Rear Bumper, 33 x 12.50 x 15 on Steel Chromies w 3.5" BS. Has new shocks, leafs. Soon; Trail Gear Sliders, ZUK brackets & coils, rear shock brackets & flip kit, Wish List; Rear lockrite, 529's, sliders (got them for $100.oo, new in box), 5 speed swap http://www.cardomain.com/ride/3171939 |
#14 (permalink) |
really???? im not much of a chevy fan so i dont know much about the 4.3.. if i did go with that option, what exactly would i need??? besides the motor...
#15 (permalink) | |
id go with a chevy motor.
__________________
91 Toyota "built not bought" Quote:
#16 (permalink) |
ok, ok... ill go with the chevy... now all i need is to know what excatly ill need for it to work out. and where ill be able to locate some of the items, or whatever
#17 (permalink) |
You have to decide if you want the chevy trans and tcase or toyota trans and tcase or chevy trans and toyota tcase. Then you'll need the adapters if you keep some of the yota stuff. Toy 4cy wont hold up, you'll need a V6 trans.
then you'll need a bigger radiator, motor mounts, tcase crossmember, drive shaft work, probably a body lift most parts can be bought from http://www.advanceadapters.com/
__________________
#18 (permalink) |
all i need is a little advice on what is the better option so i can run a carberated motor instead of fuel injection cuz of some issues im having at the moment, and all im looking for in a motor is for it to start up everyday and be a daily driver, and the occasional 4 wheel for the snow, cuz the area i live in is trying to make the town a better place, so they're getting rid of all the fun stuff and mud holes...
#19 (permalink) |
although a not very popular engine is the ford 3.8 v6 can be carb'd. will bolt to any ford v-8 trans. still decent power decent economy. and shorter than v-8 ie room in engine compartment. cheap to find any t-bird cougar just an option
#20 (permalink) |
thanks for that note... but im mainly lookin for somethin to where i can use my stock drivetrain as much as i can...
#21 (permalink) |
there is also the option of just getting a donor car that runs i found my 89 mustang 5.0 for $1000 it was cheaper than buying engine and trans seperate. then you can use the motor tranny and comp out of it replace oil pan to a rear sump and get a trans to t-case adapter
other things needed are making power steering lings if you have it making motor mounts or using advance adapters ones and switching out radiators
__________________
91' 4runner incoming 302 and sas in front and cruiser coils and chop in rear. 03' Chevy 2500HD 8.1L Vortec 89' Ford Mustang Lx parting out 93' mustang donor for hoerunner 2 Honda preludes caged and set for short leg rally |
#22 (permalink) |
ha, im in someones sig... lucky me... i was more than slightly intoxicated... but oh well... LOL. if u want the easiest, prob go with the 4.6L found in ford expeditions and F150s. theyre a reliable motor. my family has a 01 expedition with the 4.6, and it has 150,000 miles (roughly) and has never had a single problem other than an o2 sensor. and the auto tranny works great. parts are plentiful, especially now with the gas prices going up again, every1 wants to get rid of stuff.
__________________
#23 (permalink) |
Ozzie have you seen a 4.6 up close? They're pretty big. It would be way easier to go with a 5.0. They're much much narrower.
__________________
87 4Runner-Swapped in Turbo 22RE/R151 5 speed, electric fan, high-flow cat, dynomax turbo muffler, lockrights front and rear, 4" Trailmaster front bracket lift, tbars SOFT, sagged rear 3" add-a-leaf, 3" blocks, Skyjacker shocks, 3" body lift, Specialty Top/Kayline Soft Top, Ramsey 8500 winch, homemade front reciever/winch bumper, homemade rear hitch bumper, full size spare, 35x12.5-15 Radial Claws most of the time, 34x9.50-15 TSLs for 0-35" mud bogs, 5.29s |
#24 (permalink) |
ive opted to go for the chev 5.7, i have the motor, and everything for it, just need adaptor kit... im also not into the ford 4.6, the 5.0 is alot easier in my opinion, and can be carbed... which is what im lookin for... mainly for the cheapness of fixing... czu as of now, my 22re needs a new maf sensor or whatever theyre called, but ive tried another one from my old 92 pickup, but somehow they both dont work... so im just gonna go for the chev engine
#25 (permalink) |
how about makeing things really freaking easy and sticking a 22r in there? im not shure if the 22re head is the same as the 22r but that be awsome to just swap the manifold dizzy and control mod and go 350 would just add way too much weight and it seems to be way to expensive for what you whant
| Tags |
| 302, 350, 87, 88, crossmember, ford, hold, motor, mounts, pickup, sbc, sbf, speed, t18, toyota, vs |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| sbc 350 in 4runner overheating | ron2k1 | General Vehicle Related Topics (Non Year Related) | 15 | 09-05-2007 05:05 PM |
| 350/v8/sbc swap. | Anubiscougar | 86-95 Trucks & 4Runners | 3 | 12-16-2006 10:11 PM |
| built toyota truck sbc | cartune777 | The Classifieds GraveYard | 2 | 09-07-2006 07:37 AM |
| Engine SWAP - SBC | yotaman17 | 86-95 Trucks & 4Runners | 9 | 01-25-2006 07:01 PM |
| SBC/Yahoo DSL | Tacoma Dude | Computer Talk | 14 | 07-30-2005 11:43 AM |
