| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
help swapping buick 225 into my 84
__________________
the "Turtle": now the mutant turtle..... 84 ex cab 63" chevies Rears Up Front Square Drive Shaft d60f 14 bolt rear welded both with 5.38's home brew hi steer 42x15-15 TSL's TBI 4.3 V-6 pretty much stock!!! Denali offroad club: http://www.denalioffroadclub.com/for...orum/index.php |
#2 (permalink) |
well blew my 22r yesturday so this has taken a higher priority.
well i found out that the kit for the chevy and buick from advanced adapters and downey is the same kit. any one know if there is a cheaper way to get the right clutch and pressure plate? any factory application for a 10.5" 1-1/8" disc spline, with 21 splines? Also it says you have to use a high center pressure plate? how is this different from a regular pressure plate?
__________________
#3 (permalink) |
my sugestion for you would be to get a turbo 350 and adapt it that way the buick is going to shread that yota tranny alive and you can find 350 to toyota adapters everywhere for around 100 bucks
__________________
1987 Toyota 4-Runner Custom SAS All built not bought, dual cases, 4.3 chevy, turbo 350 trans, chevy 64 in the rear , chevy 46 inch springs up front, batterys relocated to rear, interior cage, (long fields 30 spline, chromo hud cogs, detroit up front, spool rear, 5.29 yukon) All gone now front 60 rear 14 bolt install goint on right now no more lifting off the skinny pedal for me!!!!, front and rear custom hitch mounts, front stinger, super heavy right foot!!!!! |
#4 (permalink) | |
Quote:
I do alot of deep snow wheeling so i didn't want an auto cause they always seem to overheat and burn up!! We will see how long the 5-speed lasts, my friend has a 351 with the stock 5-speed and has not had problems yet...and he has alot heavier foot than i!!!
__________________
#5 (permalink) |
Got cha man If you have any questions about your swap give me a shout and i will see if i can help you out. Auto trans (if you build it it will last) just my
.02
__________________
#6 (permalink) | |
Quote:
I like how the buick fits, lots of room all the way around and i think i should be able to get away with using the stock radiator for a while cause it never gets real warm up here. What radiator did you use for this swap? Also, i almost ditched the buick cause i got a free running 91 chevy with the 4.3 and 5-speed but i had already bought the conversion bell housing, and i couldn't bring my self to part a perfectly good truck!!
__________________
#7 (permalink) |
you will need to change radiators these buick motors run on the hot side as it is. Extremeradiator.com has a direct bolt in for like 180 bucks it is for a small block swap but it cools the buick great and it bolts to your exsisting holes
__________________
#8 (permalink) | |
Quote:
I saw one guy on pirate that used a stock 3.0 radiator and he was in arazona?
__________________
#9 (permalink) |
I dont think it will. I had no luck trying it. It was fine idleing but once you started moving it just keep climbing. did you check that site out
__________________
#10 (permalink) | |
Quote:
Thanks for the input! It is hard to think of overheating for me right now casue te weather has been in the -20's for about three weeks!! kind of odd to think about overheating in that weather lol
__________________
#11 (permalink) |
got cha man well if you have any other questions give a shout i will be glade to help ya out
__________________
#12 (permalink) |
thanks man.
__________________
#13 (permalink) |
So is there a good step by step kinda deal with swapping the buick into a yota. I was really considering the 5vz 3.4l but i think the buick swap could get me back on the road alot faster. My 3.0 is just tired and needs to get put to rest.
#14 (permalink) | |
Quote:
1-AA chevy adapter, which has the old buick bolt pattern also. uses a fj-60 slave and will bolt right up with the stock buick flywheel a clutch disc out of a newer3.4 taco and a gm pressure plate and throwout bearing. 2-motormounts, either buy them or fab the stock mounts to fit the buick like i did. 3- get a gm one wire alt and a factory gm HEI dist (only one hot wire) and factory gm starter with the nose cone shaved down a little. 4 wires total for the entire motor. 4- use the stock GM p/s pump with a custom made high pressure line easily made at any reputable hydraulic hose or tractor store. take in both your old toyota and the gm line and they will reuse the ends and save you alot of time and $$. 5- exhaust, you can buy a set of headers from summit for a buick regal or century from the late 70's and they will fit or you can get some stock manifolds and make them fit like i did if you want to be cheap. 6- but a v-6 swap radiator and an electric fan. I am using the stock radiator for now until summer hits cause i am not really worried cause it has been -20ºF for like 2 months and no light at the end of the tunnel so i think it should work for now. as for electric fan go get a fan from a ford taurus, make sure you get the fan with three wires coming off not two the three wire will blow twice as much air. I think that about covers it......any other questions feel free to use this thread and i or others who have done it will gladly help you out!! unless you are a ducks fan.....jsut kidding man, i am a coug and my girlfriend was a duck so i am just flipping you S@#$. good luck, alot cheaper than the 3.4 and ALOT less wiring with the carbed motor!!! parts are cheap too!!
__________________
the "Turtle": now the mutant turtle..... 84 ex cab 63" chevies Rears Up Front Square Drive Shaft d60f 14 bolt rear welded both with 5.38's home brew hi steer 42x15-15 TSL's TBI 4.3 V-6 pretty much stock!!! Denali offroad club: http://www.denalioffroadclub.com/for...orum/index.php Last edited by ryantowry_81; 01-08-2009 at 09:19 AM. |
#15 (permalink) |
TS ALIVE!!!!!! didn't get any new pics but got to hear her roar last night!!! all i got to do now is get exhaust done have my custom P/S line made and wire my electric fan and i will out for a test ride!!! i am so stoked!!!
__________________
#16 (permalink) |
some teaser pics:
motor pics: ![]() ![]() got bored with some spray on bed liner: ![]() patrick added some paint to the hood...... ![]() and the sticker: ![]() alli got to do is finish building the exhaust and mont up and plump the P/S pump and wire the fan and we should be good for sunday!!!
__________________
#17 (permalink) |
Congrats! I know the feeling!
I too sprayed on that bedliner in th exact same pattern. It easily chips off the line where the bedliner meets the paint. Otherwise its not too bad. I might do the entire truck with bedliner.
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
#18 (permalink) |
thanks man! i know i did that on another truck and had the same prob but then i got some clear coat in a spray canand covered the edges and it solved the problem.
I got to drive the truck for about 50 ft yesturday, i didn't go farther casue the clutch is still not ajusted right and i hads to start her in gear and shut it down to change gears, but i did get to hit the trottle in 2wd hi range and without using the clutch spun both rears on just slightly wet pavement!!!! that might not seem like much but with 39.5's and 4.10s i think that says something for the strength of that motor, and the choke was still on too!!! ![]() i cant wait to get her all tuned up and out on the trail!!! i might actually get out of first low range on the trail now!!
__________________
#19 (permalink) |
Oh man i remenber when i fired mine up the first time with the buick. Open headers odd fire motor everything sounds great
__________________
#20 (permalink) |
The engine compartment cleans up nicely with out all the eletronic junk in there dosent it
__________________
#21 (permalink) | |
Quote:
I havent got to drive it yet due to crazy hours at work but i am trying to and i will get video when i do!!!
__________________
#22 (permalink) |
Well i finally got to take her out across the street for some snow wheeling and only a couple little bugs to figure out and i will be set!! all i need is a better fitting rad hose cause the one i had was ghetto and burst, P/S belt, and to put on the muffler i have. also i need to get a toyota temp sender so i can know how hot the motor is without an aftermarket gauge, i like the factory look.
The power was sweet though!! i even got to use high range 4wd with out lugging out the motor with 39.5's and 4.10's!! i cant wait to get her on an actual trail!!!
__________________
#23 (permalink) |
nice to see the buick conversions still happening. I did mine in '82 and have been very happy with it, I went with the t350 because I had a stick in my smallblock Landcruiser and wanted something easier to drive on the street. I think this is the third or forth engine I put in here but would do it again if I had to. I had an aluminum Buick V8 I was going to install last time but the V6 works and fit so well I rebuilt another and put it back in. The V8 went into my friends baja bug (another great swap)
[IMG] [/IMG]
__________________
1981 Shortbed 4x4 Buick 231 V6, Turbo 350 4" springs 35x12.50 15 Bfg MT 300,000+ miles |
#24 (permalink) |
man that looks good!!! i am actually looking for an aluminum buick v-8 to put in, but i would prob go th350 with that much HP and one tons! but that is another build i guess.
so what radiator did you end up using? i have the stock one from my 4cyl right now and figure for the winter up here it will be fine but i am worried about the summer months.
__________________
#25 (permalink) |
It's a 3 row that I think I got from Downey, it was about $200 at the time but has never overheated (exept when I had a bad head gasket) even in 90*+ temps on the beach. I think it was a deal since it's lasted over 25 years. Check with a local radiator shop, they should be able to build you one using your ends and mounts if it's in good shape.
__________________
| Tags |
| 105, 21, 225, 22r, buick, clutch, convert, disc, flywheel, gm, hei, hud, issues, spline, toyota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| buick 225 v-6 in my 84 ex-cab | ryantowry_81 | 84-85 Trucks & 4Runners | 36 | 04-06-2009 12:09 PM |
| FS: stock 225 spare | AH64ID | The Classifieds GraveYard | 1 | 04-21-2007 02:18 PM |
| WTB or trade for (2) 225/75/15 at's | mtrdrms | The Classifieds GraveYard | 1 | 02-07-2007 04:57 AM |
| 225/70/15 to 265/75/16 - regear? | washington4Runner | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 10-02-2006 12:05 PM |
