| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Engine swap???
#2 (permalink) |
Search a bit more youll find the info out there
Welcome BTW
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 39" Iroks, Rear Leafswap, 5.29's , Air locked front, Welded rear, Chevy 4.3L V6, 5spd swap, dual T/C's MC10R10, flatbelly with custom skids, sliders, Chopped, Bobbed and so much more. Might as well start reading this if ya want know more |
#3 (permalink) |
Toyota Tacomas did not come out until late 1995. All the Toyota trucks previously were HILUX trucks(even though they stopped using this name in 1975) The most important difference between the older HILUX trucks (all made in Japan) and the Tacoma trucks (made in California) is that the frames on the older trucks are fully boxed (stronger) and the Tacomas, all other trucks built in California are only "C" section frames (weaker).
__________________
DEPLOYED Again! 1994 SAS 2RZ/R151F=244:1! 1988 Toyota 4Runner SR5 |
#4 (permalink) |
Does anyone know if the 5 speed used with the V6 toyota uses a bigger bell housing than the 5 speed bolted to the 4 cylinder and if so is it the same transmission bolt pattern. I need a bell housing to bolt to the 5 speed I have that is a larger diameter. I am mating this tranny to an isuzu 1.8L diesel and the smaller bell housing has interference problems with the bolt holes on the engine meaning an adapter plate is impossible to make. Any info would be greatly appreciated.
| Tags |
| 82, h2racing, hilux, motor, swap |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Engine swap | scott7689 | 86-95 Trucks & 4Runners | 11 | 12-22-2007 07:37 PM |
| 1991 4Runner body swap or engine/tranny swap? | 91slowrunner | 86-95 Trucks & 4Runners | 2 | 05-21-2007 10:11 PM |
| Engine Swap HELP! | alaskanrocket | 86-95 Trucks & 4Runners | 5 | 04-15-2007 11:43 AM |
| Engine swap/check engine light? | spacoli | 86-95 Trucks & 4Runners | 1 | 11-29-2006 07:39 PM |
| Engine Swap | nickr9287 | General Vehicle Related Topics (Non Year Related) | 6 | 11-04-2006 07:15 PM |
