Think I got in over my head: 3.4 swap help needed
Old 06-25-2010, 10:31 PM
  #81
Dewbro91's Avatar
I mean what wire on the body harness would I need to hook up to the ecu?
Old 06-25-2010, 10:36 PM
  #82
dem0nk1d's Avatar
the main signal wire from the VSS should be spliced into the ECU's SPD connector. so the vss will be hooked directly into the 3.0 dash harness side, and the vss signal wire needs to be split and tide into the ECU spd wire... This way the system picks it up
Old 06-26-2010, 09:20 AM
  #83
Dewbro91's Avatar
Ok I understand now. Don't know when Ill get to that seeing how I have everything put back together inside now. Ill be driving eight hours home on monday from CO to UT. Hopefully everything works and I wont run into problems. One thing, I've heard the oil pressure gauges arent very accurate, mine seems like its running a little low. Should I worry about this? How did you tie in the O2 heater into your ECU?
Old 06-26-2010, 08:19 PM
  #84
Dewbro91's Avatar
Well I took the runner out for about a two hour drive. Lots of hills to go up. An hour there and an hour back. Ran great!! Didn't heat up and the oil pressure seemed normal. When I tried to come back tho, the starter decided to be stupid. it wouldn't turn over. I tried and tried then my starter wire started getting real hot. So I had to pull the kick panel back off and pull the wire through the firewall and touch it to a hot wire in the fuse box. Really annoying doing all that. But then after that it started fine? I have no idea what that means, maybe a relay?
Old 06-26-2010, 08:47 PM
  #85
dem0nk1d's Avatar
i bought a new o2 for the front o2, and the rear o2 i just made the simulator. so far no rear 02 code.
Old 06-26-2010, 09:42 PM
  #86
Dewbro91's Avatar
The weird thing is my rear isn't even plugged in and the only o2 code I'm getting is for the heater circuit. Hopefully everything is functioning right
Old 06-27-2010, 09:21 AM
  #87
dem0nk1d's Avatar
whats the code... P0141 or what??? Post the code.
Old 06-27-2010, 04:04 PM
  #88
Dewbro91's Avatar
I believe it P0135
Old 06-27-2010, 06:27 PM
  #89
dem0nk1d's Avatar
that's the front o2 sensor. did you buy a new obd2 complaint o2 sensor. that would be the reason for that code.
the rear code is P0141
the vss is p0500
Old 06-28-2010, 11:36 AM
  #90
Dewbro91's Avatar
That would be my problem. I just used my old o2 sensor. I should be getting a code for the rear tho right?
Old 06-29-2010, 05:55 PM
  #91
dem0nk1d's Avatar
yeah you should. change the front one to a obd2 sensor and you should be good to go. the vss code is a whole can of worms which i'm researching at the moment. looks like ours is not sending out the correct signal to the ecu. so even if you rig it like the way i said it still will throw.
Looking into some kind of signal pulse generator. god what a f'n headache this is. once i get the vss figured out the gas mileage should go up, because the ecu is still running in limp mode.
Old 06-29-2010, 08:36 PM
  #92
Dewbro91's Avatar
Yeah tell me about it man. I thought figuring out the wires I did was hard, this VSS thing sounds like hell. I will get looking at some diagrams soon. Oh and fixed the starter problem. After I broke down in the desert (moab) I realized that the wire coming off the starter from the ignition had broke clean off. So I had to push start it and got it home. Tore the thing down and soldered the hell out of the plug to the wires inside. Fixed my problem!
Old 06-29-2010, 08:55 PM
  #93
dem0nk1d's Avatar
deadly... lol! always something right?
Old 06-30-2010, 08:52 AM
  #94
Dewbro91's Avatar
It is man! Ill keep an update with the O2 and VSS if I figure anything out
Old 07-01-2010, 07:50 PM
  #95
dem0nk1d's Avatar
Dew: VSS FIX.... WOOOOOOT I figured it out... Check the last post on
https://www.yotatech.com/forums/f160/vss-issues-214574/
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
vasinvictor
01-20-2016 12:39 PM
94whiterunner
09-22-2015 07:25 PM
Edionne13
06-21-2015 11:37 PM
duckhead
3.4 Swaps
7
06-18-2015 06:54 AM
Quick Reply: Think I got in over my head: 3.4 swap help needed
