Manual ECM PLUGS
Old 04-25-2011, 01:49 PM
Houston5's Avatar
Manual ECM PLUGS
I know that someone on here has posted the part numbers for these plugs but i have search and can't relocate it can ANYONE help?Please
Old 04-25-2011, 02:58 PM
dntsdad's Avatar
Been researching this myself and I am about 99% sure that these are correct.
Old 04-25-2011, 03:08 PM
jasond's Avatar
Not all of them are the same, its like say "I want a manual ecm" - some are similar to other years, but not a one size fits all. I posted some part numbers to the ecus that I looked up when I was doing my swap "22r to 5vz" :
Below you will find the part numbers for the plugs (c1 & c2 in the ewd) that fit into the dash harness on my 92 yota so that you dont have to cut up the 22r harness to use them...
90980-10811
90980-10881
These are empty plugs that you will have to supply the wires for, if you cant find any to use, use these part numbers, (these are per wire btw)...warning, doing it this way (ordering each wire) can get expensive in a hurry...
82998-12340 - small wire (majority of these two plugs)
82998-12380 - larger wire (only 4 of these needed in this application)
Also it seems people have had trouble in locating the plug for the body harness that plugs into the 3.4 ecu. Below you will find 4runner part numbers, I dont know for sure, but I think that the taco's p/n are the same.
96 - plug E8 90980-11392
(Manual Trans)
plug E12 90980-11218
(Auto Trans)
97/98 - plug E12 90980-11218
99/00 - plug E12 90980-11637
plug E14 90980-11638
96/97 T100 - plug E4 90980-11392
(manual trans)
Old 04-25-2011, 03:39 PM
Houston5's Avatar
Thanks Guys now if I could only locate the manual ECM.Car-Part everyone on there that is a reasonable price I called and they don't have.
Old 05-06-2011, 12:47 PM
Fernley1's Avatar
When I needed a Manual Tranmission E-4 Plug for my swap, at first I could not find one. I finally found one on a early 90's Subaru Legacy. The only differance was the plug was yellow.
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
PlayAwhile
07-20-2015 11:36 AM
icentropy
07-13-2015 10:57 AM
cars-guy
07-11-2015 07:51 PM
Quick Reply: Manual ECM PLUGS
