Coming to the end of my swap, few questions.
#47
ohh mann alright im getting tired and frustrated..
so is this another possible problem?..i looked down and seen both these wires cut that go into to the 3.0 body harness..im using one of the black and red wires that gets hot when the key is turned to "ON" and it has a inline fuse and that goes to the wire for the fuel pump off of the 3.4 ecm plug and the wire that is coming from the fuel pump that is underneath the carpet is that correct?
and where does the other thick black and red wire go to?..the COR?
thanks
thanks
#49
ah what really..guess i should of read the diagram first before taking another word for it
thats what i got from another user on here...is that the possible reason that my fuel pump doesnt shut off and its flooding the motor with fuel?
so do those two red and black wires from the 3.0 harness run to anywhere or just stay in that plug??
and where are these 2 (one from fuel pump and one from ecm) fuel pump wires supposed to go?
thanks!
thanks!
#50
The blue wire that runs to the fuel pump ran to the check connector in the 3.0 engine harness for testing the pump. An that is exactly why your fp is on when the key is on. That wire is not used in the swap harness if I recall. Look at both engine controll/ecu ewd's side by side and see how the cor is wired on both. They both get the signal from the afm/maf sensor in the intake. Do you understand the proccess of labeling and identifying the different pins/ wire colors on the ewd?
#51
I do grasp that concept..just have a hard time understanding the the wiring diagrams and how everything runs..I understand the basics ..I just don't know what I should do with the wires now?..doesn't the blue wire from the body harness get connected to the ecm with a inline fuse and the one coming from the fuel pump needs to be spliced back into where it originally goes under the carpet under the passenger seat?
#52
Vital can fill you in on how to wire the 3.0 cor to work as I know he has done this and I haven't or even looked at the design for more than a few seconds. The 3.4 is so simple I just went with that since I have many relays.
To use the 3.4 style, just go grab a relay from any car stereo shop.
85 to the g-y wire (FP) off ECM
86 & 30 to an ignition source
87 to the b-o wire to the fuel pump
To use the 3.0 setup, I believe you that you can take the FC lead from the ECM and run it to the g-y wire that is on the cor? Vital can you confirm?
#54
#55
I am going to disagree. The 3.4 setup for the cor doesnt run through the maf. It's a very simple relay setup. Power in and power out exactly like you would wire up a relay for a light or any accessory.
#56
soo anyone? if im retaining the 3.0 cor of what i said off of the picture above?
what i tried doing by experimenting was taken the g-y wire from the grey body harness plug and connecting it to the FC pin on the ecm plug but hear nothing out of the fuel pump when key is turned to "ON"..or do i have to directly splice into the g-y wire that is going into the COR?
dont wanna have to cut into everything if i dont have to.
#57
You got it right. Just did this today myself on a runner. Take the g-y from the 3.0 harness(ih1 or ih2 I can't remember) and connect it to the FC terminal off the 3.4 ECM. I think that is also g-y if I remember correctly.
It will not come on with the key in the on position. At lest the one I did today didn't either. Only when I went to crank position.
This is different that using an alternative ot the 3.4 relay. The 3.4 setup comes on in the on or start position.
#60
Just to double check if I'm right or wrong..the blue wire coming from the fuel pump is to be connected to a blue wire on the e5 plug on the ecm?..just not sure which one cause there's like three a blue and orange a blue and black and blue and yellow I think?..I'm using the one that looks to have a factory splice in it covered in a red tape/cover?
