| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Circuit opening relay confusion
#2 (permalink) |
WOOHOO I figured it out
![]() Since the '86 diagram doesn't show pin locations or anything, I mistakenly assumed that the green wire at the body connector was from the MAF....but I was wrong. The green wire from the MAF that originally grounds the Circuit opening relay does not go through any connectors, its a straight shot from the old MAF plug to the COR. It ties into the original fuel pump check connector, but that's it. Solution: Cut the green wire coming from the COR and connect it to the Green-yellow coming off of the ECM...problem solved. I read a few posts on here regarding this problem...even one who had used the ORS harness. The reason is because this appears to be the ONLY wire involved in this swap that doesn't go through any of the plugs by the ECM. Hope this helps. Now, can someone tell me how to make a '86 4 cylinder tach work with the signal from a 5VZ ECM? Last edited by lbhsbz; 10-11-2009 at 11:41 PM. |
