alternator upgrade issues.
Old 04-23-2016, 12:03 PM
mizombie's Avatar
So recently I upgraded my failing stock 5vz alternator for a new high output. The new alternator has an under drive pulley (smaller diameter) now to get proper tension the alt casing rubs on the steering column. anyone else run into this before? Wondering if going with a shorter belt would solve the problem, anyone done this and have a belt part number they would be willing to give out??
Old 04-29-2016, 12:29 PM
69sixpackbee's Avatar
I had cut the end off of my lower bracket and redrilled the mounting hole where it attaches onto the block. I took about 1-1/4" off of it. The adjusting screw just clears the plastic cover over the rag joint.
Bud
mikea71
3.4 Swaps
14
05-09-2017 10:05 AM
1985 4Runner
03-02-2016 10:24 AM
rondogracing
02-25-2016 01:32 PM
Snowking
01-29-2016 02:03 PM
Quick Reply: alternator upgrade issues.
