After this swap sitting for almost a year Im ready to finish it with some help...?
#65
It's always the fallback, I really want to try the 1uz tho.... knock on wood, but my 3.0 seems like it's got a lot of years left too
#67
3 scoops ordered. Thanks again. We will have to post up some pics after they are installed.
#69
Had it on the road a little over 800 miles and pulled a check engine light... wierd thing is it goes on for a bit but when the truck has been sitting for a few hours and I take off. half the time it will go off and stay off, until the next couple times I start my truck, then goes back on. I guess I will just have to pull the codes and see whats the deal!
#71
Ever figure out which codes??
The scoops came in yesterday. Can't wait to get it all buttoned up. We will have to post pics when we install them.
#73
just wondering how far the Supercharger sits above where the Hood is, I have a 2" BL that I put on so I could avoid cutting my hood. But that was before I even discovered the 3.4 Supercharged was my option for engine swap.
#74
With 2" lift you wont have any problems. I was able to close my hood without even cutting a hole, just the under hood supports... but it did leave a small dent and would rub on the underside of the hood when it rev'd.
So as far as how much clearance is need to fit the S/C..?
Not much!
#76
Sweet rig!
I'm doing this swap now & was wondering if you have any body lift on this truck and what did you do for the exhaust cross-over?
I like the hood scoop idea but I was concerned about exhaust to firewall clearance without doing a body lift.
#77
As far as the crossover I built my own but it took a few trial and errors. Toyonly swaps sells them for like $125, well worth it in my opinion and it looks a lot nicer than mine turned out!
#79
I noticed in your sig you're supercharged with plans on urd fuel mods. How well has the supercharger without any fuel mods worked? I'm reading anything from it pings quite a bit to people have no issues with running the supercharger without the urd fuel mods? Are you running any type of fuel enrichment other than stock?
#80
Good luck on yours, do the research and everything will fall into place. Any questions feel free to ask. I dont mind answering what I can.
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
