88 pickup 5vzfe swap
im trying to get my 3.4 ready to drop into my pickup by the end o the week. i have read alot on this website about this swap but it seemsthat i cant find anyone that is having the same issue as me. i have both motor mounts from the 3.0 on but i m trying to mount the power steering pump bracket back up but it will not fit due to the height of the bolt thats on the motor mount. what have people done to fix this issue? will the 3.0 power steering pump mount move over and work? use the grinder on the mount? or just use a bolt with a smaller head? thank you for your help
For some reason, your motor mount doesn't look like it's the same one as mine. Are you sure it's a 3.0 mount?
It looks like you've cut it off, but the top holes should mount up to the uppermost holes you see in the first picture.
