Single lube for 99 4Runner Chassis?
Is there a single lube that is safe to use on all chassis zerk fittings for a 1999 4Runner? I know that the manual calls for different grease but I thought maybe there was some new and improved one size fits all.
Thanks in advance!
Thanks in advance!
Excellent, thanks for the replies. I am getting the clunk when moving forward from a stop. The search I did turned up the possibility of needing grease. Will try this weekend and see if it helps.
I just bought a 98 limited and just lubed the drive shafts. What else should I lubed to stop that clunking? What is making that clunk?
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
icentropy
07-09-2015 02:12 PM
