self adjusting break question
Ok i just put some new shoes on the rear of the runner and they seem to get to tight after a day of driving (causing the truck to lurch to a stop) if i were to drive on snow and ice i would believe that that would cause me to loose control. what do you guys think i should do? I have loosened them up a bit and cleaned them again but I think they are going to tighten up again. I replace the old one because they were dragging and the shoe material had gotten so hot that they cracked.
David
David
1 Post
Dragging brakes is rarely the fault of the shoe or pad. You've got an internal problem. Perhaps someone with more experience has seen this before. FYI, most 'self-adjusting' brakes require you to use the parking brake frequently.
