Power steering fluid
Old 03-30-2005, 07:38 PM
Localmotion's Avatar
Power steering fluid for camry
I have a friend who has a 1996 toyota camry and i recently threw some power steering fluid into her resivor. It was making noises as she was turning so i figured it was the PS fluid. I went to autozone and got some Prestone Power steering fluid plus stop leak I have been looking on line and people have been using ATF fluid and some Dexcron stuff? Will it matter whats inside her PS pump now or should i flush it out and put new stuff in it?
thanks and sorry for the long post
matt
Localmotion is offline
Old 03-31-2005, 05:17 AM
mt_goat's Avatar
Yes, flush it out. https://www.yotatech.com/forums/show...power+steering
If it hasn't started leaking yet you may be ok. It seems the seals and o-rings in the pump don't like PS fluid as much as Dexron III ATF. My manual (93 truck) says to use ATF. The noises are a worry though, if the pump was run dry at some point it may be toast. If it is just leaking a rebuild kit can be had for cheap.
http://members.cox.net/stacewilliams/ps-pump.htm
mt_goat is offline
Old 03-31-2005, 06:43 AM
PirateFins's Avatar
Look at the cap of her PS and see what it calls for. But most of the Toy's use ATF.
PirateFins is offline
Old 03-31-2005, 09:54 AM
mt_goat's Avatar
I should have mentioned that when I flushed with the method in the link posted above I used 2 quarts of ATF just turning the wheel from lock to lock and back to straight again. I stopped the motor every few seconds to refill.
mt_goat is offline
Old 03-31-2005, 12:09 PM
CRAPP!!! does that mean i screwed her PS up? What damages could it do? how much would it cost if i screwd her PS up? sorry for the questions, now im all paranoid about iot. Im gonna have to go back down there and flush it out. eeeeekkkk.
matt
Old 03-31-2005, 12:23 PM
mt_goat's Avatar
The PS pump seal kit for our trucks is only about $25, so it's not that bad. It sounds like maybe it was already leaking huh, if it needed fluid.
mt_goat is offline
Old 04-03-2005, 10:42 AM
kyle_22r's Avatar
i don't think PS fluid will damage anything, it's just not the best stuff to run in a toyota.
kyle_22r is offline
Zpd426
01-02-2016 01:15 PM
Up&Down
08-11-2015 10:04 AM
gmonnie123
07-26-2015 02:44 PM
yoterr
07-24-2015 04:29 AM
whereAreMyPants
07-22-2015 03:32 AM
Quick Reply: Power steering fluid
